TensorFlow model not using swap memory even when using cpu
I added swap memory for my Jetson Nano because the 4GB was not enough. Because GPU memory is not shared with the swap memory, I instead tried to do inferencing with cpu and did:
os.environ['CUDA_VISIBLE_DEVICES'] = '-1'
However, only 25% of swap memory is used and then out of memory error. Does this mean I was not using the CPU all along?
hi @ju81153
Can you please refer this topic, hope this will help you Swap memory is not being used by the code
Thank you
Could you share the output log of TensorFlow with us first?
