I installed tensorflow object detection API on Jeston TX2 according to https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/installation.md. But I can not verity the installation by “python object_detection/builders/model_builder_test.py”.
My situation is:
nvidia@tegra-ubuntu:~/API/models-master/research$ python3 object_detection/builders/model_builder_test.py
WARNING:tensorflow:From /usr/local/lib/python3.5/dist-packages/tensorflow/contrib/learn/python/learn/datasets/base.py:198: retry (from tensorflow.contrib.learn.python.learn.datasets.base) is deprecated and will be removed in a future version.
Instructions for updating:
Use the retry module or similar alternatives.
EEEEEEEEEEEEEE.
ERROR: test_create_embedded_ssd_mobilenet_v1_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 515, in test_create_embedded_ssd_mobilenet_v1_model_from_config
model = self.create_model(model_proto)
File “object_detection/builders/model_builder_test.py”, line 69, in create_model
return model_builder.build(model_config, is_training=True)
File “/home/nvidia/API/models-master/research/object_detection/builders/model_builder.py”, line 98, in build
add_background_class)
File “/home/nvidia/API/models-master/research/object_detection/builders/model_builder.py”, line 166, in _build_ssd_model
is_training=is_training)
File “/home/nvidia/API/models-master/research/object_detection/builders/model_builder.py”, line 129, in _build_ssd_feature_extractor
feature_extractor_config.override_base_feature_extractor_hyperparams)
AttributeError: ‘SsdFeatureExtractor’ object has no attribute ‘override_base_feature_extractor_hyperparams’
ERROR: test_create_faster_rcnn_inception_resnet_v2_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 859, in test_create_faster_rcnn_inception_resnet_v2_model_from_config
model = model_builder.build(model_proto, is_training=True)
File “/home/nvidia/API/models-master/research/object_detection/builders/model_builder.py”, line 101, in build
add_summaries)
File “/home/nvidia/API/models-master/research/object_detection/builders/model_builder.py”, line 278, in _build_faster_rcnn_model
frcnn_config.inplace_batchnorm_update)
AttributeError: ‘FasterRcnn’ object has no attribute ‘inplace_batchnorm_update’
ERROR: test_create_faster_rcnn_inception_v2_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 926, in test_create_faster_rcnn_inception_v2_model_from_config
add_summaries)
ERROR: test_create_faster_rcnn_model_from_config_with_example_miner (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 984, in test_create_faster_rcnn_model_from_config_with_example_miner
add_summaries)
ERROR: test_create_faster_rcnn_nas_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 725, in test_create_faster_rcnn_nas_model_from_config
add_summaries)
ERROR: test_create_faster_rcnn_pnas_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 792, in test_create_faster_rcnn_pnas_model_from_config
add_summaries)
ERROR: test_create_faster_rcnn_resnet101_with_mask_prediction_enabled (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 661, in test_create_faster_rcnn_resnet101_with_mask_prediction_enabled
add_summaries)
ERROR: test_create_faster_rcnn_resnet_v1_models_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 581, in test_create_faster_rcnn_resnet_v1_models_from_config
text_format.Merge(model_text_proto, model_proto)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 536, in Merge
descriptor_pool=descriptor_pool)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 590, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 623, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 638, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 763, in _MergeField
merger(tokenizer, message, field)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 837, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File “/usr/local/lib/python3.5/dist-packages/google/protobuf/text_format.py”, line 730, in _MergeField
(message_descriptor.full_name, name))
google.protobuf.text_format.ParseError: 3:9 : Message type “object_detection.protos.FasterRcnn” has no field named “inplace_batchnorm_update”.
ERROR: test_create_rfcn_resnet_v1_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 1050, in test_create_rfcn_resnet_v1_model_from_config
add_summaries)
ERROR: test_create_ssd_inception_v2_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 137, in test_create_ssd_inception_v2_model_from_config
google.protobuf.text_format.ParseError: 15:11 : Message type “object_detection.protos.SsdFeatureExtractor” has no field named “override_base_feature_extractor_hyperparams”.
ERROR: test_create_ssd_inception_v3_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 209, in test_create_ssd_inception_v3_model_from_config
ERROR: test_create_ssd_mobilenet_v1_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 367, in test_create_ssd_mobilenet_v1_model_from_config
google.protobuf.text_format.ParseError: 3:9 : Message type “object_detection.protos.Ssd” has no field named “freeze_batchnorm”.
ERROR: test_create_ssd_mobilenet_v2_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 443, in test_create_ssd_mobilenet_v2_model_from_config
ERROR: test_create_ssd_resnet_v1_fpn_model_from_config (main.ModelBuilderTest)
File “object_detection/builders/model_builder_test.py”, line 295, in test_create_ssd_resnet_v1_fpn_model_from_config
