I have been trying to test the object detection code in the following NVIDIA repository to test object detection API:
git clone https://github.com/AastaNV/ObjectDetection
I can successfully run the model SSD_mobilenet_v1_coco_2017_11_17; however, when I try to run model SSD_mobilenet_v2_coco_2018_03_29 using
$ python3 object_detection-1.py
I get the following error:
File "/home/amin/.local/lib/python3.6/site-packages/tensorflow/python/framework/importer.py", line 426, in import_graph_def
graph._c_graph, serialized, options) # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: Node 'Preprocessor/map/while/ResizeImage/stack_1': Unknown input node '^Preprocessor/map/while/Identity'
The full error detail is as follows:
2019-06-27 15:33:09.240724: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2019-06-27 15:33:09.243031: I tensorflow/compiler/xla/service/service.cc:161] XLA service 0x18b5a5f0 executing computations on platform Host. Devices:
2019-06-27 15:33:09.243112: I tensorflow/compiler/xla/service/service.cc:168] StreamExecutor device (0): <undefined>, <undefined>
2019-06-27 15:33:09.317514: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:965] ARM64 does not support NUMA - returning NUMA node zero
2019-06-27 15:33:09.318012: I tensorflow/compiler/xla/service/service.cc:161] XLA service 0x16221790 executing computations on platform CUDA. Devices:
2019-06-27 15:33:09.318070: I tensorflow/compiler/xla/service/service.cc:168] StreamExecutor device (0): NVIDIA Tegra X1, Compute Capability 5.3
2019-06-27 15:33:09.318425: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: NVIDIA Tegra X1 major: 5 minor: 3 memoryClockRate(GHz): 0.9216
pciBusID: 0000:00:00.0
totalMemory: 3.87GiB freeMemory: 666.36MiB
2019-06-27 15:33:09.318499: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-06-27 15:33:15.223866: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-06-27 15:33:15.223933: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-06-27 15:33:15.223956: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-06-27 15:33:15.224098: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 114 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
During handling of the above exception, another exception occurred:
File "object_detection-1.py", line 88, in <module>
tf.import_graph_def(remove, name='')
File "/home/amin/.local/lib/python3.6/site-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/home/amin/.local/lib/python3.6/site-packages/tensorflow/python/framework/importer.py", line 430, in import_graph_def
raise ValueError(str(e))
ValueError: Node 'Preprocessor/map/while/ResizeImage/stack_1': Unknown input node '^Preprocessor/map/while/Identity'
Could you please help how I can resolve the issue?
