I have flashed Jetpack 3.3 on Jetson TX2 , then install OpenCV and tensorflow wheel as per the instructions. But I got the following error while running the demo for tf_tr_models for detection. I have tried several times to install flash TX2 with differents versions of Jetpack as well.
INFO:main:called with args: Namespace(conf_th=0.3, do_build=False, do_tensorboard=False, filename=‘examples/detection/data/huskies.jpg’, image_height=480, image_width=640, labelmap_file=‘third_party/models/research/object_detection/data/mscoco_label_map.pbtxt’, model=‘ssd_mobilenet_v1_coco’, num_classes=None, rtsp_latency=200, rtsp_uri=None, use_file=False, use_image=True, use_rtsp=False, use_usb=False, video_dev=0)
INFO:main:reading label map
INFO:main:opening camera device/file
INFO:main:loading TRT graph from pb: ./data/ssd_mobilenet_v1_coco_trt.pb
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py”, line 489, in import_graph_def
graph._c_graph, serialized, options) # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: NodeDef mentions attr ‘Truncate’ not in Op<name=Cast; signature=x:SrcT → y:DstT; attr=SrcT:type; attr=DstT:type>; NodeDef: Cast = CastDstT=DT_FLOAT, SrcT=DT_UINT8, Truncate=false. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
During handling of the above exception, another exception occurred:
File “camera_tf_trt.py”, line 199, in
main()
File “camera_tf_trt.py”, line 167, in main
trt_graph = load_trt_pb(pb_path)
File “/home/nvidia/tf_trt_models/utils/od_utils.py”, line 83, in load_trt_pb
tf.import_graph_def(trt_graph_def, name=‘’)
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/deprecation.py”, line 432, in new_func
return func(*args, **kwargs)
File “/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py”, line 493, in import_graph_def
raise ValueError(str(e))
ValueError: NodeDef mentions attr ‘Truncate’ not in Op<name=Cast; signature=x:SrcT → y:DstT; attr=SrcT:type; attr=DstT:type>; NodeDef: Cast = CastDstT=DT_FLOAT, SrcT=DT_UINT8, Truncate=false. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
