Hey all, I’m having a problem converting a pretrained keras model of vgg16 to a .uff file and then converting that to a .trt file for inference on the Xavier. This is the code I’m using for the conversion:
model = ka.vgg16.VGG16(include_top=False, weights='imagenet')
output_names = [node.op.name for node in model.outputs]
frozen_graph_filename = 'keras_vgg16_frozen_graph.pb'
uff_model_name = "keras_vgg16_model.uff"
sess = k.get_session()
# freeze graph and remove training nodes
graph_def = tf.graph_util.convert_variables_to_constants(sess, sess.graph_def, output_names)
graph_def = tf.graph_util.remove_training_nodes(graph_def)
# write frozen graph to file
with open(frozen_graph_filename, 'wb') as f:
f.write(graph_def.SerializeToString())
f.close()
# convert frozen graph to uff
uff_model = uff.from_tensorflow_frozen_model(frozen_graph_filename, output_names)
with open(uff_model_name, 'wb') as f:
f.write(uff_model)
f.close()
This appears works fine but when I try to then convert the output .uff file to a trt file I get this error:
ERROR: Parameter check failed at: ../builder/Network.cpp::addInput::406, condition: isValidDims(dims)
ERROR: UFFParser: Failed to parseInput for node input_1
ERROR: UFFParser: Parser error: input_1: Failed to parse node - Invalid Tensor found at node input_1
My code to do the conversion is:
import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.UffParser() as parser:
parser.register_input("Placeholder", [3, 224, 224], order=trt.UffInputOrder.NCHW)
parser.register_output("output")
parser.parse("keras_vgg16_model.uff", network, weights_type=trt.DataType.FLOAT)
I feel like I’m running around in cirlces trying to get this work so any help would be appreciated. For understanding I’m doing this all on a host machine as PoC before hopefully trying it out on the Xavier in c++
