Description
Following the example shown at TensorRT/quickstart/IntroNotebooks/4. Using PyTorch through ONNX.ipynb at master · NVIDIA/TensorRT · GitHub
I wonder how can I create the bindings for a model that has more than one output array.
I will really appreciate clear suggestions.
NVES
June 23, 2021, 8:38pm
2
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Thanks for your feedback.
I get error when I try converting using trtexec.
The trtexec ouput is here
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=resnet18_2_outputs.onnx --saveEngine=resnet_engine_pytorch.trt --explicitBatch --inputIOFormats=fp16:chw --outputIOFormats=fp16:chw --fp16
[06/24/2021-11:46:09] [I] === Model Options ===
[06/24/2021-11:46:09] [I] Format: ONNX
[06/24/2021-11:46:09] [I] Model: resnet18_2_outputs.onnx
[06/24/2021-11:46:09] [I] Output:
[06/24/2021-11:46:09] [I] === Build Options ===
[06/24/2021-11:46:09] [I] Max batch: explicit
[06/24/2021-11:46:09] [I] Workspace: 16 MB
[06/24/2021-11:46:09] [I] minTiming: 1
[06/24/2021-11:46:09] [I] avgTiming: 8
[06/24/2021-11:46:09] [I] Precision: FP32+FP16
**[06/24/2021-11:46:09] [I] Calibration: **
[06/24/2021-11:46:09] [I] Safe mode: Disabled
[06/24/2021-11:46:09] [I] Save engine: resnet_engine_pytorch.trt
**[06/24/2021-11:46:09] [I] Load engine: **
[06/24/2021-11:46:09] [I] Builder Cache: Enabled
[06/24/2021-11:46:09] [I] NVTX verbosity: 0
[06/24/2021-11:46:09] [I] Input: fp16:chw
[06/24/2021-11:46:09] [I] Output: fp16:chw
[06/24/2021-11:46:09] [I] Input build shapes: model
[06/24/2021-11:46:09] [I] Input calibration shapes: model
[06/24/2021-11:46:09] [I] === System Options ===
[06/24/2021-11:46:09] [I] Device: 0
**[06/24/2021-11:46:09] [I] DLACore: **
[06/24/2021-11:46:09] [I] Plugins:
[06/24/2021-11:46:09] [I] === Inference Options ===
[06/24/2021-11:46:09] [I] Batch: Explicit
[06/24/2021-11:46:09] [I] Input inference shapes: model
[06/24/2021-11:46:09] [I] Iterations: 10
[06/24/2021-11:46:09] [I] Duration: 3s (+ 200ms warm up)
[06/24/2021-11:46:09] [I] Sleep time: 0ms
[06/24/2021-11:46:09] [I] Streams: 1
[06/24/2021-11:46:09] [I] ExposeDMA: Disabled
[06/24/2021-11:46:09] [I] Spin-wait: Disabled
[06/24/2021-11:46:09] [I] Multithreading: Disabled
[06/24/2021-11:46:09] [I] CUDA Graph: Disabled
[06/24/2021-11:46:09] [I] Skip inference: Disabled
[06/24/2021-11:46:09] [I] Inputs:
[06/24/2021-11:46:09] [I] === Reporting Options ===
[06/24/2021-11:46:09] [I] Verbose: Disabled
[06/24/2021-11:46:09] [I] Averages: 10 inferences
[06/24/2021-11:46:09] [I] Percentile: 99
[06/24/2021-11:46:09] [I] Dump output: Disabled
[06/24/2021-11:46:09] [I] Profile: Disabled
**[06/24/2021-11:46:09] [I] Export timing to JSON file: **
**[06/24/2021-11:46:09] [I] Export output to JSON file: **
**[06/24/2021-11:46:09] [I] Export profile to JSON file: **
**[06/24/2021-11:46:09] [I] **
Input filename: resnet18_2_outputs.onnx
ONNX IR version: 0.0.6
Opset version: 9
Producer name: pytorch
Producer version: 1.6
**Domain: **
Model version: 0
Doc string: **
terminate called after throwing an instance of ‘std::invalid_argument’
** what(): The number of outputIOFormats must match network’s outputs.
Please find my onnx file here resnet18_2_outputs.onnx - Google Drive
Hi @source821 ,
We recommend you to try on latest TensorRT version. We are able to generate engine successfully when we run on TensorRT latest version 8.0 EA.
&&&& PASSED TensorRT.trtexec [TensorRT v8000] # trtexec --onnx=/my_data/181682_arrays/model.onnx --saveEngine=resnet_engine_pytorch.trt --explicitBatch --inputIOFormats=fp16:chw --outputIOFormats=fp16:chw --fp16 --verbose
[06/24/2021-16:59:58] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 2339, GPU 14450 (MiB)
Thank you.
Thanks I will give it a try.
