TensorRT engine ONNX error while running a python script using DeepStream
Hello.
Can anyone help me with this error:
ubuntu@ubuntu-Blade-15-2022-RZ09-0421:~/Documents/DeepStream-Yolo-Face$ python3 deepstream.py -s file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 -c config_infer_primary_yoloV8_face.txt
SOURCE: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
CONFIG_INFER: config_infer_primary_yoloV8_face.txt
STREAMMUX_BATCH_SIZE: 1
STREAMMUX_WIDTH: 1920
STREAMMUX_HEIGHT: 1080
GPU_ID: 0
PERF_MEASUREMENT_INTERVAL_SEC: 5
JETSON: FALSE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:03.153337617 31142 0x2ae9860 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/home/ubuntu/Documents/DeepStream-Yolo-Face/yolov8n-face.onnx_b1_gpu0_fp32.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT input 3x640x640
1 OUTPUT kFLOAT boxes 8400x4
2 OUTPUT kFLOAT scores 8400x1
3 OUTPUT kFLOAT landmarks 8400x0
0:00:03.208580298 31142 0x2ae9860 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /home/ubuntu/Documents/DeepStream-Yolo-Face/yolov8n-face.onnx_b1_gpu0_fp32.engine
python3: nvdsinfer_context_impl.cpp:1377: NvDsInferStatus nvdsinfer::NvDsInferContextImpl::resizeOutputBufferpool(uint32_t): Assertion `bindingDims.numElements > 0’ failed.
Aborted (core dumped)
Please, I wonder if anyone could help me with this issue, how can I fix it?
DeepStream Version = 6.3
YOLO MODEL = Yolov8n-face
CUDA = 12.3
TensorRT = 8.5.3.1
NVIDIA GRAPHIC = GeForce RTX 3080 Ti
32GB RAM and 1TB SSD
yolov8n-face.onnx (11.8 MB)
Since I don’t have a 3080ti, I tried running it on T4 and jetson and both worked fine.
Not sure if onnx is exported correctly, you can try this model.
Hence we are closing this topic. If need further support, please open a new one. Thanks
