Here is the logger while using tensorrt to parse my uff model. I don’t know how to deal with this proble and this model can work on tensorflow.
[TensorRT] INFO: UFFParser: parsing input
[TensorRT] INFO: UFFParser: parsing Reshape/shape
[TensorRT] INFO: UFFParser: parsing Variable
[TensorRT] INFO: UFFParser: parsing Conv2D
[TensorRT] INFO: UFFParser: parsing Variable_1
[TensorRT] INFO: UFFParser: parsing add
[TensorRT] INFO: UFFParser: parsing Relu
[TensorRT] INFO: UFFParser: parsing MaxPool
[TensorRT] INFO: UFFParser: Pooling: add Padding Layer to support asymmetric padding
[TensorRT] INFO: UFFParser: Pooling: Left: 0
[TensorRT] INFO: UFFParser: Pooling: Right: 1
[TensorRT] INFO: UFFParser: Pooling: Top: 0
[TensorRT] INFO: UFFParser: Pooling: Bottom: 0
[TensorRT] INFO: UFFParser: parsing Variable_2
[TensorRT] INFO: UFFParser: parsing Conv2D_1
[TensorRT] INFO: UFFParser: parsing Variable_3
[TensorRT] INFO: UFFParser: parsing add_1
[TensorRT] INFO: UFFParser: parsing Relu_1
[TensorRT] INFO: UFFParser: parsing MaxPool_1
[TensorRT] INFO: UFFParser: parsing Reshape_1/shape
[TensorRT] INFO: UFFParser: parsing Variable_4
[TensorRT] INFO: UFFParser: parsing MatMul
[TensorRT] INFO: UFFParser: parsing Variable_5
[TensorRT] INFO: UFFParser: parsing add_2
[TensorRT] INFO: UFFParser: parsing Relu_2
[TensorRT] INFO: UFFParser: parsing Variable_6
[TensorRT] INFO: UFFParser: parsing MatMul_1
[TensorRT] INFO: UFFParser: parsing Variable_7
[TensorRT] INFO: UFFParser: parsing add_3
[TensorRT] INFO: UFFParser: parsing output
[TensorRT] INFO: UFFParser: parsing MarkOutput_0
[TensorRT] ERROR: add: kernel weights has count 800 but 25600 was expected
[TensorRT] ERROR: add_2: kernel weights has count 1048576 but 131072 was expected
[TensorRT] ERROR: Failed to create engine
File "/usr/local/lib/python2.7/dist-packages/tensorrt/utils/_utils.py", line 74, in uff_file_to_trt_engine
assert(engine)
File "./face_api.py", line 58, in <module>
main()
File "./face_api.py", line 53, in main
trt.trt_test(args.cnn_model_path,args.video)
File "/home/wly/trainspace/dlib/face_project5/lib/face_interface_trt.py", line 65, in trt_test
egine = trt.utils.uff_file_to_trt_engine(G_LOGGER,uff_path,parser,MAX_BATCHSIZE,MAX_WORKSPACE,trt.infer.DataType.FLOAT)
File "/usr/local/lib/python2.7/dist-packages/tensorrt/utils/_utils.py", line 82, in uff_file_to_trt_engine
raise AssertionError('UFF parsing failed on line {} in statement {}'.format(line, text))
AssertionError: UFF parsing failed on line 74 in statement assert(engine)
