Tensorrt inference in real time
Description
I have converted my model.onnx to createdEngine.engine using the following command:
/usr/src/tensorrt/bin/trtexec --onnx=/home/isl/fall_keras_model/keras_fall_model_onnx.onnx --saveEngine=/home/isl/success_engine.engine
Also in a python script I have the following code:
import cv2
from cvzone.HandTrackingModule import HandDetector
from cvzone.ClassificationModule import Classifier
import numpy as np
import math
final_output = “”
letters =
count_frames = 20
cap = cv2.VideoCapture(0)
detector = HandDetector(maxHands=1)
classifier = Classifier(“fall_keras_model.h5”, “fall_labels.txt”)
offset = 50
imgSize = 300
counter = 0
labels = [“A”, “B”, “back”, “C”, “D”, “E”, “F”, “G”, “H”, “I”, “J”, “K”, “L”, “M”,
“N”, “O”, “P”, “Q”, “R”, “S”, “space”, “T”, “U”, “V”, “W”, “X”, “Y”, “Z”] #back, space, j, z
while True:
success, img = cap.read()
hands = detector.findHands(img, draw=False)
filtered = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
filtered = cv2.GaussianBlur(filtered, (5, 5), 2)
filtered = cv2.adaptiveThreshold(filtered, 255, cv2.ADAPTIVE_THRESH_GAUSSIAN_C, cv2.THRESH_BINARY_INV, 11, 2)
ret, filtered = cv2.threshold(filtered, 170, 255, cv2.THRESH_BINARY_INV + cv2.THRESH_OTSU)
cv2.imshow(“Original”, img)
if hands:
hand = hands[0]
x, y, w, h = hand[‘bbox’]
imgWhite = np.ones((imgSize, imgSize), np.uint8)*255
imgCrop = filtered[y-offset : y+h+offset, x-offset : x+w+offset]
imgCropShape = imgCrop.shape
aspectRatio = h/w
try:
	if aspectRatio > 1:
		k = imgSize/h
		wCal = math.ceil(k*w)
		imgResize = cv2.resize(imgCrop, (wCal, imgSize))
		imgResizeShape = imgResize.shape
		wGap = math.ceil((imgSize-wCal)/2)
		imgWhite[:, wGap:wCal+wGap] = imgResize
		gray2rgb = cv2.cvtColor(imgWhite, cv2.COLOR_GRAY2RGB)
    	else:
		k = imgSize / w
		hCal = math.ceil(k * h)
		imgResize = cv2.resize(imgCrop, (imgSize, hCal))
		hGap = math.ceil((imgSize - hCal) / 2)
		imgWhite[hGap:hCal + hGap, :] = imgResize
	prediction, index = classifier.getPrediction(gray2rgb)
    	#print(labels[index])
	count_frames -= 1
	lett = lett.replace(lett, "")
	if count_frames == 0:
		count_frames = 20
		lett = max(letters, key = letters.count)
		letters.clear()
		if lett == "space":
		    final_output += " "
		elif lett == "back":
		    final_output = final_output[0:len(final_output)-1]
		else:
		    final_output += lett
	else:
		letters.append(labels[index])
	#print(prediction)
	if (x-offset > 0 and x+offset < img.shape[1]  and  y-offset > 0  and  y+offset < img.shape[0]):
		#cv2.imshow("Filtered", filtered)
		#cv2.imshow("Cropped", imgCrop)
		imgWhite = cv2.putText(imgWhite, final_output, (50,50), cv2.FONT_HERSHEY_SIMPLEX, 1, (255,0,255), 2, cv2.LINE_AA)
		cv2.imshow("Final", imgWhite)
except:
		print("ERROR: Hand out of frame")
key = cv2.waitKey(1)
if key == ord(‘q’):
cap.release()
cv2.destroyAllWindows()
ISSUE: i want to run this converted .engine tensorrt engine and pass my input image to get the prediction, so how should I load the engine in the above code and run it?
Environment
TensorRT Version: 8.0.6.1
GPU Type: Jetson Nano
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version: Ubuntu 18.04+
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
