Description
Generated engine file from onnx model using trtexec.
Model accepts two inputs, image feature and token sequence as it’s image captioning model.
I can see successful inference when load engine file with trtexec --loadEngine.
My concern is how I can do it with python.
Below is the inference code
def infer(engine):
input_image = preprocess(input_file)
sequence_token = token_preprocess()
with engine.create_execution_context() as context:
# Set input shape based on image dimensions for inference
context.set_binding_shape(0, (1, 4096))
context.set_binding_shape(1, (1, 35))
# Allocate host and device buffers
bindings = []
for binding in engine:
binding_idx = engine.get_binding_index(binding)
size = trt.volume(context.get_binding_shape(binding_idx))
dtype = trt.nptype(engine.get_binding_dtype(binding))
if engine.binding_is_input(binding):
if binding_idx == 0:
input_buffer = np.ascontiguousarray(input_image)
input_memory = cuda.mem_alloc(input_image.nbytes)
bindings.append(int(input_memory))
else:
input_buffer = np.ascontiguousarray(sequence_token)
input_memory = cuda.mem_alloc(sequence_token.nbytes)
else:
output_buffer = cuda.pagelocked_empty(8485, dtype)
output_memory = cuda.mem_alloc(output_buffer.nbytes)
bindings.append(int(output_memory))
stream = cuda.Stream()
# Transfer input data to the GPU.
cuda.memcpy_htod_async(input_memory, input_buffer, stream)
# Run inference
context.execute_async_v2(bindings=bindings, stream_handle=stream.handle)
# Transfer prediction output from the GPU.
cuda.memcpy_dtoh_async(output_buffer, output_memory, stream)
# Synchronize the stream
stream.synchronize()
Getting following error when try to inference
[TRT] [E] 1: [defaultAllocator.cpp::deallocate::61] Error Code 1: Cuda Runtime (invalid argument)
Environment
TensorRT Version: 8.6
CUDA Version: 12.0
