Tensorrt on python docker container image
Is it possible to use tensorrt on a docker image based on python on a jetson nano? I know that L4T TensorRT exists. But those images are very big, Gigabytes for an image where I just run a simply python app
You will still need all the dependencies installed inside the container (ex. CUDA, cuDNN, TensorRT).
So please use the L4T TensorRT image.
Is there at least a way to reduce that image size?
You can try to build your own image on the top of l4t-base.
