I have created an onnx model that successfully with TensorRT 7 on my host machine, but it gives the following error on AGX Xavier (Jetpack 4.3).
[TensorRT] ERROR: (Unnamed Layer* 0) [Convolution]: at least 5 dimensions are required for input
File “run.py”, line 49, in
engine = backend.prepare(model, device=‘CUDA:0’)
File “/home/yaak/onnx-tensorrt/onnx_tensorrt/backend.py”, line 200, in prepare
return TensorRTBackendRep(model, device, **kwargs)
File “/home/yaak/onnx-tensorrt/onnx_tensorrt/backend.py”, line 86, in init
raise RuntimeError(msg)
RuntimeError: While parsing node number 1:
builtin_op_importers.cpp:695 In function importBatchNormalization:
[6] Assertion failed: scale_weights.shape == weights_shape
On AGX Xavier, I have followed the instructions at https://github.com/onnx/onnx-tensorrt/tree/6.0-full-dims
and I have also installed the TensorRT 6.0 open source libaries and onnx 1.5.0.
The model is open source (r2plus1d_34_clip32_ft_kinetics_from_ig65m-ade133f1.pth] and is taken from https://github.com/moabitcoin/ig65m-pytorch
I have converted the .pth to .onnx using torch 1.2.0 (also using the 1.3 gives the same error)
And used the following script to build a trt engine for it:
import onnx
import onnx_tensorrt.backend as backend
import numpy as np
model = onnx.load(“r2plus1d_34_clip32_ft_kinetics_from_ig65m-10f4c3bf.onnx”)
input_data = np.random.random(size=(1, 3, 32, 224, 224)).astype(np.float32)
output_data = engine.run(input_data)[0]
print(output_data)
print(output_data.shape)
I appreciate it if you can help me resolving this error.
Nasim
