Hi NV,
environment:
cuda10 tensorRT:7
tensorflow 1.13.2
I am working on using uffparser to parser my uff file which is generated by frozen graph.
Here is the issue:
I tried to slice net tensor which is [1, 44, 152, 3] in tensorflow.
net_1 should be [1,44,152, 1] in tensorflow.
but during uffparser process,input node is model/decoder/Conv_19/BiasAdd → [3,44,152]
net_1 order becomes [44, 152, 1]. I think net_1 order should be [1, 44, 152]. the order of net_1 is wrong. How to make it becomes [1, 44, 152] during uffparser?
The snippet code of tensorflow:
net_1 = tf.strided_slice(net, begin = [0, 0, 0, 0], end = [1, net.shape[1], net.shape[2], 1], strides = [1, 1, 1, 1])
net_2 = tf.strided_slice(net, begin = [0, 0, 0, 1], end = [1, net.shape[1], net.shape[2], 2], strides = [1, 1, 1, 1])
net_3 = tf.strided_slice(net, begin = [0, 0, 0, 2], end = [1, net.shape[1], net.shape[2], 3], strides = [1, 1, 1, 1])
theta = tf.nn.sigmoid(net_1) * 3.1415926535 / 6
phi = tf.nn.sigmoid(net_2) * 3.1415926535 * 2
dist = tf.nn.sigmoid(net_3) * self.max_depth
n1 = tf.multiply(tf.math.sin(theta), tf.math.cos(phi))
n2 = tf.multiply(tf.math.sin(theta), tf.math.sin(phi))
n3 = tf.math.cos(theta)
net = tf.concat([n1, n2, n3, dist], axis=3)
the verbose of ussparser:
[TensorRT] VERBOSE: UFFParser: model/decoder/Conv_19/BiasAdd → [3,44,152]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: model/decoder/Conv_19/BiasAdd
[TensorRT] VERBOSE: UFFParser: Parsing model/decoder/StridedSlice/begin[Op: Const].
[TensorRT] VERBOSE: UFFParser: model/decoder/StridedSlice/begin → [4]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: model/decoder/StridedSlice/begin
[TensorRT] VERBOSE: UFFParser: Parsing model/decoder/StridedSlice/end[Op: Const].
[TensorRT] VERBOSE: UFFParser: model/decoder/StridedSlice/end → [4]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: model/decoder/StridedSlice/end
[TensorRT] VERBOSE: UFFParser: Parsing model/decoder/StridedSlice/strides[Op: Const].
[TensorRT] VERBOSE: UFFParser: model/decoder/StridedSlice/strides → [4]
[TensorRT] VERBOSE: UFFParser: Applying order forwarding to: model/decoder/StridedSlice/strides
[TensorRT] VERBOSE: UFFParser: Parsing model/decoder/StridedSlice[Op: StridedSlice]. Inputs: model/decoder/Conv_19/BiasAdd, model/decoder/StridedSlice/begin, model/decoder/StridedSlice/end, model/decoder/StridedSlice/strides
[TensorRT] VERBOSE: UFFParser: model/decoder/StridedSlice → [44,152,1]
