I have converted a Caffe2 inception model into ONNX, and am now trying to load the model and convert to TRT:
nvonnxparser::IOnnxConfig* config = nvonnxparser::createONNXConfig();
config->setModelFileName(modelONNXFilePath.c_str());
// create parser object
nvonnxparser::IONNXParser* parser = nvonnxparser::createONNXParser(*config);
gLogger = parser->getLogger();
if(!parser->parse(modelONNXFilePath.c_str(), nvinfer1::DataType::kFLOAT)){
std::string msg("failed to parse onnx file");
gLogger->log(nvinfer1::ILogger::Severity::kERROR, msg.c_str());
exit(EXIT_FAILURE);
if(!parser->convertToTRTNetwork()){
std::string msg("ERROR, failed to convert onnx network into TRT network");
exit(EXIT_FAILURE);
network = parser->getTRTNetwork();
After running this on the ONNX model I get the error: “Attribute not found: shape”. I googled around for this error, and thus far it seems like I am using some layer that is not supported in ONNX. I peaked around and at the end of the network, we use a “Dropout” layer. From what I understand, during inference this layer essentially becomes a no-op. So I tried manually removing the op from my caffe2 protobuf file, and reconverted into ONNX, but I am still getting the ‘shape’ error.
So two questions:
How can I improve debugging so I can see what exactly is the error?
Is there something I am missing for converting this model?
Here is the model, which contains the ‘dropout’ layer: https://drive.google.com/open?id=1GtIEDEl_aZvmnf4hSHRpOz9XryWjKuFr
If needed I provide the onnx model for the version that I manually removed the dropout layer from the pbtxt file.
Thanks for any help!
Quick update. Ran a sample model completely removing the dropout layer, but still having the “Attribute not found: shape” error.
The layers we are using from Caffe2 are:
Conv, Relu, MaxPool, Concat, AveragePool, FC, and Softmax.
Maybe it is the name “FC”, that is causing the issue??
As far as I know, in ONNX this gets converted too:
^Hpool11_1
^KOC2_DUMMY_1^R^KOC2_DUMMY_0"^GReshape
J
^KOC2_DUMMY_0
^Ffc_w_0
^Ffc_b_0^R^Dfc_1"^DGemm*^M
^FtransB^X^A ^A^B*^P
broadcast^X^A ^A^B
After further looking (again), I found this issue from 15 days ago: Why is there an additional Reshape layer in LeNet's onnx pb file ? · Issue #1025 · onnx/onnx · GitHub
Apparently onnx is creating this layer to complement the FC layer, which converts things into a separate shape…
So most likely I will need to implement a custom layer using the plugin interface, but how to do this prior to loading the model using the convertToTRTNetwork for loading onnx?
Edit:
Another quick update, my colleague tried to remove the automatically generated layer by doing a squeeze operation to flatten the tensor to match the input from the GEMM layer. Using TensorRT 4, it shows support for Squeeze, but I am getting the following output:
convert_tensor softmax_1
convert_tensor fc_1
convert_tensor fc_input_1
input: "pool11_1"
output: "fc_input_1"
op_type: "Squeeze"
attribute {
ints: 2
ints: 3
type: INTS
terminate called after throwing an instance of 'std::out_of_range'
what(): No converter registered for op type: Squeeze
E0611 10:47:14.960438 693 main.cpp:62] *** Aborted at 1528728434 (unix time) try "date -d @1528728434" if you are using GNU date ***
E0611 10:47:14.961580 693 main.cpp:62] PC: @ 0x7f1f927d0428 gsignal
E0611 10:47:14.961833 693 main.cpp:62] *** SIGABRT (@0x138a000002b5) received by PID 693 (TID 0x7f1fa7af6740) from PID 693; stack trace: ***
E0611 10:47:14.962733 693 main.cpp:62] @ 0x7f1f93417390 (unknown)
E0611 10:47:14.963565 693 main.cpp:62] @ 0x7f1f927d0428 gsignal
E0611 10:47:14.964376 693 main.cpp:62] @ 0x7f1f927d202a abort
E0611 10:47:14.965319 693 main.cpp:62] @ 0x7f1f92e0a84d __gnu_cxx::__verbose_terminate_handler()
E0611 10:47:14.966382 693 main.cpp:62] @ 0x7f1f92e086b6 (unknown)
E0611 10:47:14.967200 693 main.cpp:62] @ 0x7f1f92e08701 std::terminate()
E0611 10:47:14.968183 693 main.cpp:62] @ 0x7f1f92e08919 __cxa_throw
E0611 10:47:14.969714 693 main.cpp:62] @ 0x7f1f99509119 nvonnxparser::Converter::convert_node()
E0611 10:47:14.971324 693 main.cpp:62] @ 0x7f1f9950b1d1 nvonnxparser::Converter::convert_tensor_or_weights()
E0611 10:47:14.976142 693 main.cpp:62] @ 0x7f1f99500dd1 nvonnxparser::convert_Gemm()
E0611 10:47:14.977587 693 main.cpp:62] @ 0x7f1f99508a95 nvonnxparser::Converter::convert_node()
E0611 10:47:14.979106 693 main.cpp:62] @ 0x7f1f9950b1d1 nvonnxparser::Converter::convert_tensor_or_weights()
E0611 10:47:14.980360 693 main.cpp:62] @ 0x7f1f9950405d nvonnxparser::convert_Softmax()
E0611 10:47:14.981259 693 main.cpp:62] @ 0x7f1f99511752 nvonnxparser::parserONNX::convertToTRTNetwork()
Any updates since? I have similar issues, having run a PyTorch - ONNX conversion for a resnet model.
