Environment:
OS: Ubuntu 18.04.1 LTS
Device: GeForce GTX 108…
Driver Version: 410.66
CUDA Version: 10.0
CUDNN Version: 7.3.1
TensorRT Version: 5.0.0-1+cuda10.0
Tensorflow Version: 1.10.0
Python: Python 3.6.6
UFF Model:
https://drive.google.com/file/d/1gA2_UYWVlQxMR9p5iKDFvW_nw82SRTeP/view?usp=sharing
Frozen model:
https://drive.google.com/file/d/1I4HEPbSRcJGMT5jjjhShjPRHlXrnlQc0/view?usp=sharing
UFF Text:
https://drive.google.com/file/d/1c8bjymImQEhYpSodDrWAtSOHJ_oZpME3/view?usp=sharing
I am attempting to load a uff file created from tensorflow research slim inception_reznet_v2 that i have trained and frozen. The UFF file seems to be generated by the following code corectly with output from my uff python script.
=== Automatically deduced input nodes ===
[name: "input"
op: "Placeholder"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
Using output node InceptionResnetV2/Logits/Predictions
Converting to UFF graph
No. nodes: 2009
UFF Output written to //output/flowers-irv2/flowers/saved_frozen/inception_resnet_v2_inference_frozen.uff
When I attempt to load this UFF graph using tensorrt5 i recive the following output.
ERROR: InceptionResnetV2/InceptionResnetV2/Mixed_5b/concat: all concat input tensors must have the same dimensions except on the concatenation axis
ERROR: InceptionResnetV2/InceptionResnetV2/Repeat/block35_1/Branch_0/Conv2d_1x1/Conv2D: at least three non-batch dimensions are required for input
ERROR: UFFParser: Parser error: InceptionResnetV2/InceptionResnetV2/Repeat/block35_1/Branch_0/Conv2d_1x1/BatchNorm/FusedBatchNorm: The input to the Scale Layer is required to have a minimum of 3 dimensions.
The code for loading the uff file is as follows.
parser->registerInput("input", DimsNCHW(1, 3, 299, 299), nvuffparser::UffInputOrder::kNHWC);
parser->registerOutput("InceptionResnetV2/Logits/Predictions");
maxBatchSize = maximumBatchSize;
IBuilder* builder = createInferBuilder(logger);
INetworkDefinition* network = builder->createNetwork();
parser->parse(uffFile, *network, nvinfer1::DataType::kFLOAT);
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize((1 << 30));
engine = builder->buildCudaEngine(*network);
net definition slightly modified from research slim to remove calls from slim.flatten which isn’t supported.
# Copyright 2016 The TensorFlow Authors. All Rights Reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
"""Contains the definition of the Inception Resnet V2 architecture.
As described in http://arxiv.org/abs/1602.07261.
Inception-v4, Inception-ResNet and the Impact of Residual Connections
on Learning
Christian Szegedy, Sergey Ioffe, Vincent Vanhoucke, Alex Alemi
from __future__ import absolute_import
from __future__ import division
from __future__ import print_function
import tensorflow as tf
slim = tf.contrib.slim
def block35(net, scale=1.0, activation_fn=tf.nn.relu, scope=None, reuse=None):
"""Builds the 35x35 resnet block."""
with tf.variable_scope(scope, 'Block35', [net], reuse=reuse):
with tf.variable_scope('Branch_0'):
tower_conv = slim.conv2d(net, 32, 1, scope='Conv2d_1x1')
with tf.variable_scope('Branch_1'):
tower_conv1_0 = slim.conv2d(net, 32, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1_0, 32, 3, scope='Conv2d_0b_3x3')
with tf.variable_scope('Branch_2'):
tower_conv2_0 = slim.conv2d(net, 32, 1, scope='Conv2d_0a_1x1')
tower_conv2_1 = slim.conv2d(tower_conv2_0, 48, 3, scope='Conv2d_0b_3x3')
tower_conv2_2 = slim.conv2d(tower_conv2_1, 64, 3, scope='Conv2d_0c_3x3')
mixed = tf.concat(axis=3, values=[tower_conv, tower_conv1_1, tower_conv2_2])
up = slim.conv2d(mixed, net.get_shape()[3], 1, normalizer_fn=None,
activation_fn=None, scope='Conv2d_1x1')
scaled_up = up * scale
if activation_fn == tf.nn.relu6:
# Use clip_by_value to simulate bandpass activation.
scaled_up = tf.clip_by_value(scaled_up, -6.0, 6.0)
net += scaled_up
if activation_fn:
net = activation_fn(net)
return net
def block17(net, scale=1.0, activation_fn=tf.nn.relu, scope=None, reuse=None):
"""Builds the 17x17 resnet block."""
with tf.variable_scope(scope, 'Block17', [net], reuse=reuse):
tower_conv = slim.conv2d(net, 192, 1, scope='Conv2d_1x1')
tower_conv1_0 = slim.conv2d(net, 128, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1_0, 160, [1, 7],
scope='Conv2d_0b_1x7')
tower_conv1_2 = slim.conv2d(tower_conv1_1, 192, [7, 1],
scope='Conv2d_0c_7x1')
mixed = tf.concat(axis=3, values=[tower_conv, tower_conv1_2])
net += scaled_up
if activation_fn:
return net
def block8(net, scale=1.0, activation_fn=tf.nn.relu, scope=None, reuse=None):
"""Builds the 8x8 resnet block."""
with tf.variable_scope(scope, 'Block8', [net], reuse=reuse):
tower_conv1_0 = slim.conv2d(net, 192, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1_0, 224, [1, 3],
scope='Conv2d_0b_1x3')
tower_conv1_2 = slim.conv2d(tower_conv1_1, 256, [3, 1],
scope='Conv2d_0c_3x1')
net += scaled_up
if activation_fn:
return net
def inception_resnet_v2_base(inputs,
final_endpoint='Conv2d_7b_1x1',
output_stride=16,
align_feature_maps=False,
scope=None,
activation_fn=tf.nn.relu):
"""Inception model from http://arxiv.org/abs/1602.07261.
Constructs an Inception Resnet v2 network from inputs to the given final
endpoint. This method can construct the network up to the final inception
block Conv2d_7b_1x1.
Args:
inputs: a tensor of size [batch_size, height, width, channels].
final_endpoint: specifies the endpoint to construct the network up to. It
can be one of ['Conv2d_1a_3x3', 'Conv2d_2a_3x3', 'Conv2d_2b_3x3',
'MaxPool_3a_3x3', 'Conv2d_3b_1x1', 'Conv2d_4a_3x3', 'MaxPool_5a_3x3',
'Mixed_5b', 'Mixed_6a', 'PreAuxLogits', 'Mixed_7a', 'Conv2d_7b_1x1']
output_stride: A scalar that specifies the requested ratio of input to
output spatial resolution. Only supports 8 and 16.
align_feature_maps: When true, changes all the VALID paddings in the network
to SAME padding so that the feature maps are aligned.
scope: Optional variable_scope.
activation_fn: Activation function for block scopes.
Returns:
tensor_out: output tensor corresponding to the final_endpoint.
end_points: a set of activations for external use, for example summaries or
losses.
Raises:
ValueError: if final_endpoint is not set to one of the predefined values,
or if the output_stride is not 8 or 16, or if the output_stride is 8 and
we request an end point after 'PreAuxLogits'.
if output_stride != 8 and output_stride != 16:
raise ValueError('output_stride must be 8 or 16.')
padding = 'SAME' if align_feature_maps else 'VALID'
end_points = {}
def add_and_check_final(name, net):
end_points[name] = net
return name == final_endpoint
with tf.variable_scope(scope, 'InceptionResnetV2', [inputs]):
with slim.arg_scope([slim.conv2d, slim.max_pool2d, slim.avg_pool2d],
stride=1, padding='SAME'):
# 149 x 149 x 32
net = slim.conv2d(inputs, 32, 3, stride=2, padding=padding,
scope='Conv2d_1a_3x3')
if add_and_check_final('Conv2d_1a_3x3', net): return net, end_points
# 147 x 147 x 32
net = slim.conv2d(net, 32, 3, padding=padding,
scope='Conv2d_2a_3x3')
if add_and_check_final('Conv2d_2a_3x3', net): return net, end_points
# 147 x 147 x 64
net = slim.conv2d(net, 64, 3, scope='Conv2d_2b_3x3')
if add_and_check_final('Conv2d_2b_3x3', net): return net, end_points
# 73 x 73 x 64
net = slim.max_pool2d(net, 3, stride=2, padding=padding,
scope='MaxPool_3a_3x3')
if add_and_check_final('MaxPool_3a_3x3', net): return net, end_points
# 73 x 73 x 80
net = slim.conv2d(net, 80, 1, padding=padding,
scope='Conv2d_3b_1x1')
if add_and_check_final('Conv2d_3b_1x1', net): return net, end_points
# 71 x 71 x 192
net = slim.conv2d(net, 192, 3, padding=padding,
scope='Conv2d_4a_3x3')
if add_and_check_final('Conv2d_4a_3x3', net): return net, end_points
# 35 x 35 x 192
scope='MaxPool_5a_3x3')
if add_and_check_final('MaxPool_5a_3x3', net): return net, end_points
# 35 x 35 x 320
with tf.variable_scope('Mixed_5b'):
tower_conv = slim.conv2d(net, 96, 1, scope='Conv2d_1x1')
tower_conv1_0 = slim.conv2d(net, 48, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1_0, 64, 5,
scope='Conv2d_0b_5x5')
tower_conv2_0 = slim.conv2d(net, 64, 1, scope='Conv2d_0a_1x1')
tower_conv2_1 = slim.conv2d(tower_conv2_0, 96, 3,
tower_conv2_2 = slim.conv2d(tower_conv2_1, 96, 3,
with tf.variable_scope('Branch_3'):
tower_pool = slim.avg_pool2d(net, 3, stride=1, padding='SAME',
scope='AvgPool_0a_3x3')
tower_pool_1 = slim.conv2d(tower_pool, 64, 1,
scope='Conv2d_0b_1x1')
net = tf.concat(
[tower_conv, tower_conv1_1, tower_conv2_2, tower_pool_1], 3)
if add_and_check_final('Mixed_5b', net): return net, end_points
# TODO(alemi): Register intermediate endpoints
net = slim.repeat(net, 10, block35, scale=0.17,
activation_fn=activation_fn)
# 17 x 17 x 1088 if output_stride == 8,
# 33 x 33 x 1088 if output_stride == 16
use_atrous = output_stride == 8
with tf.variable_scope('Mixed_6a'):
tower_conv = slim.conv2d(net, 384, 3, stride=1 if use_atrous else 2,
padding=padding,
tower_conv1_0 = slim.conv2d(net, 256, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1_0, 256, 3,
tower_conv1_2 = slim.conv2d(tower_conv1_1, 384, 3,
padding=padding,
tower_pool = slim.max_pool2d(net, 3, stride=1 if use_atrous else 2,
padding=padding,
scope='MaxPool_1a_3x3')
net = tf.concat([tower_conv, tower_conv1_2, tower_pool], 3)
if add_and_check_final('Mixed_6a', net): return net, end_points
# TODO(alemi): register intermediate endpoints
with slim.arg_scope([slim.conv2d], rate=2 if use_atrous else 1):
net = slim.repeat(net, 20, block17, scale=0.10,
if add_and_check_final('PreAuxLogits', net): return net, end_points
if output_stride == 8:
# TODO(gpapan): Properly support output_stride for the rest of the net.
raise ValueError('output_stride==8 is only supported up to the '
'PreAuxlogits end_point for now.')
# 8 x 8 x 2080
with tf.variable_scope('Mixed_7a'):
tower_conv = slim.conv2d(net, 256, 1, scope='Conv2d_0a_1x1')
tower_conv_1 = slim.conv2d(tower_conv, 384, 3, stride=2,
padding=padding,
tower_conv1 = slim.conv2d(net, 256, 1, scope='Conv2d_0a_1x1')
tower_conv1_1 = slim.conv2d(tower_conv1, 288, 3, stride=2,
padding=padding,
tower_conv2 = slim.conv2d(net, 256, 1, scope='Conv2d_0a_1x1')
tower_conv2_1 = slim.conv2d(tower_conv2, 288, 3,
tower_conv2_2 = slim.conv2d(tower_conv2_1, 320, 3, stride=2,
padding=padding,
tower_pool = slim.max_pool2d(net, 3, stride=2,
padding=padding,
net = tf.concat(
[tower_conv_1, tower_conv1_1, tower_conv2_2, tower_pool], 3)
if add_and_check_final('Mixed_7a', net): return net, end_points
net = slim.repeat(net, 9, block8, scale=0.20, activation_fn=activation_fn)
net = block8(net, activation_fn=None)
# 8 x 8 x 1536
net = slim.conv2d(net, 1536, 1, scope='Conv2d_7b_1x1')
if add_and_check_final('Conv2d_7b_1x1', net): return net, end_points
raise ValueError('final_endpoint (%s) not recognized', final_endpoint)
def inception_resnet_v2(inputs, num_classes=1001, is_training=True,
dropout_keep_prob=0.8,
reuse=None,
scope='InceptionResnetV2',
create_aux_logits=True,
"""Creates the Inception Resnet V2 model.
Args:
inputs: a 4-D tensor of size [batch_size, height, width, 3].
Dimension batch_size may be undefined. If create_aux_logits is false,
also height and width may be undefined.
num_classes: number of predicted classes. If 0 or None, the logits layer
is omitted and the input features to the logits layer (before dropout)
are returned instead.
is_training: whether is training or not.
dropout_keep_prob: float, the fraction to keep before final layer.
reuse: whether or not the network and its variables should be reused. To be
able to reuse 'scope' must be given.
create_aux_logits: Whether to include the auxilliary logits.
activation_fn: Activation function for conv2d.
Returns:
net: the output of the logits layer (if num_classes is a non-zero integer),
or the non-dropped-out input to the logits layer (if num_classes is 0 or
None).
end_points: the set of end_points from the inception model.
end_points = {}
with tf.variable_scope(scope, 'InceptionResnetV2', [inputs],
reuse=reuse) as scope:
with slim.arg_scope([slim.batch_norm, slim.dropout],
is_training=is_training):
net, end_points = inception_resnet_v2_base(inputs, scope=scope,
if create_aux_logits and num_classes:
with tf.variable_scope('AuxLogits'):
aux = end_points['PreAuxLogits']
aux = slim.avg_pool2d(aux, 5, stride=3, padding='VALID',
aux = slim.conv2d(aux, 128, 1, scope='Conv2d_1b_1x1')
aux = slim.conv2d(aux, 768, aux.get_shape()[1:3],
padding='VALID', scope='Conv2d_2a_5x5')
aux_shape = aux.get_shape().as_list()
if aux_shape[0] == None:
aux_shape[0] = -1
aux = tf.reshape(aux, [aux_shape[0], aux_shape[1] * aux_shape[2] * aux_shape[3]])
aux = slim.fully_connected(aux, num_classes, activation_fn=None,
scope='Logits')
end_points['AuxLogits'] = aux
with tf.variable_scope('Logits'):
# TODO(sguada,arnoegw): Consider adding a parameter global_pool which
# can be set to False to disable pooling here (as in resnet_*()).
kernel_size = net.get_shape()[1:3]
if kernel_size.is_fully_defined():
net = slim.avg_pool2d(net, kernel_size, padding='VALID',
scope='AvgPool_1a_8x8')
else:
net = tf.reduce_mean(net, [1, 2], keep_dims=True, name='global_pool')
end_points['global_pool'] = net
if not num_classes:
net_shape = net.get_shape().as_list()
if net_shape[0] == None:
net_shape[0] = -1
net = tf.reshape(net, [net_shape[0], net_shape[1] * net_shape[2] * net_shape[3]])
net = slim.dropout(net, dropout_keep_prob, is_training=is_training,
scope='Dropout')
end_points['PreLogitsFlatten'] = net
logits = slim.fully_connected(net, num_classes, activation_fn=None,
scope='Logits')
end_points['Logits'] = logits
end_points['Predictions'] = tf.nn.softmax(logits, name='Predictions')
return logits, end_points
inception_resnet_v2.default_image_size = 299
def inception_resnet_v2_arg_scope(weight_decay=0.00004,
batch_norm_decay=0.9997,
batch_norm_epsilon=0.001,
"""Returns the scope with the default parameters for inception_resnet_v2.
Args:
weight_decay: the weight decay for weights variables.
batch_norm_decay: decay for the moving average of batch_norm momentums.
batch_norm_epsilon: small float added to variance to avoid dividing by zero.
Returns:
a arg_scope with the parameters needed for inception_resnet_v2.
# Set weight_decay for weights in conv2d and fully_connected layers.
with slim.arg_scope([slim.conv2d, slim.fully_connected],
weights_regularizer=slim.l2_regularizer(weight_decay),
biases_regularizer=slim.l2_regularizer(weight_decay)):
batch_norm_params = {
'decay': batch_norm_decay,
'epsilon': batch_norm_epsilon,
'fused': None, # Use fused batch norm if possible.
# Set activation_fn and parameters for batch_norm.
with slim.arg_scope([slim.conv2d], activation_fn=activation_fn,
normalizer_fn=slim.batch_norm,
normalizer_params=batch_norm_params) as scope:
return scope
