the hard environment is: windows-wsl2; rtx2060; ubuntu2004
the software environment is:
numpy 1.20.2
nvidia-cublas-cu11 2021.10.25
nvidia-cublas-cu115 11.7.4.6
nvidia-cuda-runtime-cu11 2021.10.25
nvidia-cuda-runtime-cu115 11.5.117
nvidia-cudnn-cu11 2021.12.8
nvidia-cudnn-cu115 8.3.1.22
nvidia-pyindex 1.0.9
nvidia-tensorrt 8.2.1.8
pycuda 2020.1
pytools 2021.2.9
PyYAML 6.0
requests 2.26.0
six 1.16.0
torch 1.9.0+cpu
torchvision 0.10.0+cpu
test tensorrt8 & pytorch example like : cd xxxx/TensorRT/samples/python/network_api_pytorch_mnist/
python3 sample.py
the error is :
Train Epoch: 2 [57600/60000 (96%)] Loss: 0.047320
Test set: Average loss: 0.0623, Accuracy: 9798/10000 (98%)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:45: DeprecationWarning: Use add_convolution_nd instead.
conv1 = network.add_convolution(input=input_tensor, num_output_maps=20, kernel_shape=(5, 5), kernel=conv1_w, bias=conv1_b)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:46: DeprecationWarning: Use stride_nd instead.
conv1.stride = (1, 1)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:48: DeprecationWarning: Use add_pooling_nd instead.
pool1 = network.add_pooling(input=conv1.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:49: DeprecationWarning: Use stride_nd instead.
pool1.stride = (2, 2)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:53: DeprecationWarning: Use add_convolution_nd instead.
conv2 = network.add_convolution(pool1.get_output(0), 50, (5, 5), conv2_w, conv2_b)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:54: DeprecationWarning: Use stride_nd instead.
conv2.stride = (1, 1)
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:56: DeprecationWarning: Use add_pooling_nd instead.
pool2 = network.add_pooling(conv2.get_output(0), trt.PoolingType.MAX, (2, 2))
/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py:57: DeprecationWarning: Use stride_nd instead.
pool2.stride = (2, 2)
[12/29/2021-19:10:37] [TRT] [W] GPU error during getBestTactic: (Unnamed Layer* 0) [Convolution] : invalid argument
[12/29/2021-19:10:37] [TRT] [W] GPU error during getBestTactic: (Unnamed Layer* 2) [Convolution] : invalid argument
[12/29/2021-19:10:37] [TRT] [E] 10: [optimizer.cpp::computeCosts::2011] Error Code 10: Internal Error (Could not find any implementation for node (Unnamed Layer* 2) [Convolution].)
[12/29/2021-19:10:37] [TRT] [E] 2: [builder.cpp::buildSerializedNetwork::609] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed. )
File “/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py”, line 118, in
main()
File “/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py”, line 102, in main
engine = build_engine(weights)
File “/opt/TensorRT/samples/python/network_api_pytorch_mnist/sample.py”, line 85, in build_engine
return runtime.deserialize_cuda_engine(plan)
TypeError: deserialize_cuda_engine(): incompatible function arguments. The following argument types are supported:
1. (self: tensorrt.tensorrt.Runtime, serialized_engine: buffer) → tensorrt.tensorrt.ICudaEngine
Invoked with: <tensorrt.tensorrt.Runtime object at 0x7fa49fb7a0f0>, None
