You’d expect that setting the GPU governor to performance would consistently result in improved performance compared to the default. And indeed it does sometimes - but I can also consistently demonstrate it having a terrible effect on performance - increasing the run time of a standard GPU benchmark by an order of magnitude.
This is not the result of thermal throttling - in fact on the bad runs things run so slowly that the heatsink is noticeably cooler to touch than normal.
I installed the SSD-Mobilenet-V2 benchmark (as described in the Nvidia deep learning inference benchmarking instructions page) and then ran the benchmark with various governor and clock settings.
The key factor seems to be starting from a just rebooted system. If I reboot the system, set the CPU and GPU governors to performance and then run the SSD-Mobilenet-V2 benchmark, it consistently shows a terrible run time of around 12 minutes. If I rerun the benchmark multiple times it makes no difference - once it has run slowly the first time, it consistently runs slowly.
However, if I do something slightly different then things perform more as expected. If I reboot the system, set just the CPU governors to performance and then run the benchmark, it gives an acceptable time of around 4m 40s. But what’s interesting is that if I now set the GPU governor to performance and rerun the benchmark then, as expected and desired, I get an improved time. Rather than the terrible time of 12 minutes, it runs in about 3m 50s.
So it seems if, after boot, I immediately set the GPU governor to performance then I get terrible times. However if I “exercise” the GPU first and only then set the GPU governor to performance, I get the improved performance I expect.
Notes:
- My system is set not to boot into graphical mode, so the GPU is used purely for benchmark work.
- I want to use the CPU and GPU governors in performance mode, rather than using `jetson_clocks`, as I still want thermal throttling when necessary. With the governors set to performance, this is still possible but it is essentially disabled if `jetson_clocks` has been used to prevent all the clocks from going to anything below their the maximum frequency.
- Nvpmodel is set to MAXN.
- I'm running using the recommended micro-USB power supply.
Testing
This all sounds so unlikely that I’m guessing you think I’m making some kind of mistake here - but I can consistently show this behavior and have rechecked my steps each time. I’ve outlined these steps below and also include links to two scripts on GitHub that I used to repeatedly restart my Nano and run these steps.
The first script sets the CPU and GPU governors to performance and runs the SSD-Mobilenet-V2 benchmark three times (with pauses to avoid any heat-related issues) and then reboots the system. I’ve left it rerunning repeatedly overnight and consistently get a run time of around 12 minutes per run of the benchmark.
The second script sets the CPU governors to performance, runs the SSD-Mobilenet-V2 benchmark once, then additionally sets the GPU governor to performance, runs the benchmark again and then reboots the system. I’ve left it rerunning repeatedly overnight and consistently get a run time of around 3m 50s for the second run of the benchmark.
If you try these scripts make sure you’ve just rebooted your Nano before the first run.
Prerequisites
I conducted all my tests on a Nano that has been set up:
- Not to boot into graphical mode.
- Not to require a password for `sudo`.
- To allow password-less SSH login using SSH keys.
I always used WiFi, rather than wired Ethernet, to connect to the Nano.
1. Turn off requiring a password for sudo:
$ sudo visudo
And change the following line:
%sudo ALL=(ALL:ALL) ALL
To:
%sudo ALL=(ALL:ALL) NOPASSWD: ALL
2. By default the Nano boots into graphical mode:
$ systemctl get-default
graphical.target
Disable this as we want to reserve the GPU completely for benchmarking:
$ sudo systemctl set-default multi-user.target
We want WiFi to start automatically but by default, it only starts if someone has logged in (typically via the GNOME display manager). So change this:
$ cd /etc/NetworkManager/system-connections
$ ls
Assuming there’s just one file here (named the same as your WiFi network), edit this file:
$ sudo vim *
And find the line starting permissions
, it should be of the form:
permissions=user:my-user-name:;
Remove everything after the =
leaving just:
permissions=
3. Setting up SSH keys to allow password-less SSH login to the Nano.
This is slightly more involved than the other steps and I’m presuming many people already know how to do this - so I’m not going to include a tutorial here. There are many such tutorials on the web, e.g. this one from DigitalOcean.
Benchmarking
To try things by hand (assuming you’ve already installed the SSD-Mobilenet-V2 benchmark in /usr/src/tensorrt/bin
as per the Nvidia benchmarks page) the steps are as follows.
Reboot the system:
$ sudo reboot now
After logging in, following the reboot, set the CPU governors:
$ for gov in /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
do
echo performance | sudo tee -a $gov
done
Then set the GPU governor:
$ echo performance | sudo tee -a /sys/devices/57000000.gpu/devfreq/57000000.gpu/governor
Go to the benchmarks directory:
$ cd /usr/src/tensorrt/bin
Check the GPU temperature etc. before running the benchmark:
$ timeout 2s tegrastats
Run the benchmark, using time
to give a total time (as well as the times output by the benchmark):
$ time sudo ./sample_uff_ssd_rect
Check the GPU temperature etc. after running the benchmark:
Results
If I run through the steps as above the benchmark consistently takes about 12m to run. And no matter how many times I rerun sample_uff_ssd_rect
it takes a similar amount of time.
However if I reboot the system and skip the setting of the GPU governor, run sample_uff_ssd_rect
once, and then set the GPU governor, I get much better results when rerunning sample_uff_ssd_rect
Scripts
I’ve created two scripts called bad-performance
and good-performance
Both reboot the system on completion and I’ve run both repeatedly overnight from a remote system (to confirm that I get consistent results) like so:
$ while true
do
date
ssh jetson@jetsonnano.local ./bad-performance
sleep 120
done
Obviously, you’ll need to change jetson
to the username appropriate for your setup, and change bad-performance
to good-performance
if you want to run the other script.
The bad-performance
script reruns the benchmark three times - showing that it consistently achieves a terrible runtime of 12m.
The good-performance
script runs the benchmark twice, first without the GPU governor set to performance and then with it set to performance. For comparison it also runs two additional setups:
- The GPU governor set to its default but with the GPU min_freq set to max.
- All clocks etc. set to max with `jetson_clocks`.
As expected using jetson_clocks
results in the best overall performance but setting all the CPU and GPU governors to performance is almost as good (and probably better when used e.g. in a robot setup, as the governors can still enable thermal throttling when necessary).
You can find the steps for these four comparisons laid out in more detail here.
You can find logs (captured using script
) of running both scripts repeatedly overnight (using the above while
loop) in bad-typescript.txt
and good-typescript.txt
