While testing the NPP twist API on CUDA 12.3, I noticed something unusual and would like to ask a question.
Why does processing the same input values produce different results between the planar in-place method and the packed in-place API?
result:
R G B | Twist_IP3R | Twist_C3IR
TestCase | Y Cb Cr | Y Cb Cr
DarkRed ( 2, 0, 0) 2 0 0 | 0 127 129 | 1 128 129
source code:
#include "gtest/gtest.h"
#include <cuda_runtime.h>
#include <npp.h>
class TwistIP3RvsC3IRTest : public ::testing::Test {
protected:
static void SetUpTestSuite() {
// POC: Compare nppiColorTwist32f_8u_IP3R_Ctx vs nppiColorTwist32f_8u_C3IR_Ctx
TEST_F(TwistIP3RvsC3IRTest, POC_TWIST_IP3R_VS_C3IR) {
struct TestCase {
const char* name;
uint8_t r, g, b;
std::vector<TestCase> testCases = {
{"DarkRed ( 2, 0, 0)", 2, 0, 0},
NppStreamContext nppCtx = {};
int deviceId = 0;
cudaGetDevice(&deviceId);
nppCtx.hStream = nullptr;
nppCtx.nCudaDeviceId = deviceId;
cudaDeviceGetAttribute(&nppCtx.nMultiProcessorCount, cudaDevAttrMultiProcessorCount, deviceId);
cudaDeviceGetAttribute(&nppCtx.nMaxThreadsPerMultiProcessor, cudaDevAttrMaxThreadsPerMultiProcessor, deviceId);
cudaDeviceGetAttribute(&nppCtx.nMaxThreadsPerBlock, cudaDevAttrMaxThreadsPerBlock, deviceId);
int sharedMem = 0;
cudaDeviceGetAttribute(&sharedMem, cudaDevAttrMaxSharedMemoryPerBlock, deviceId);
nppCtx.nSharedMemPerBlock = static_cast<size_t>(sharedMem);
cudaDeviceGetAttribute(&nppCtx.nCudaDevAttrComputeCapabilityMajor, cudaDevAttrComputeCapabilityMajor, deviceId);
cudaDeviceGetAttribute(&nppCtx.nCudaDevAttrComputeCapabilityMinor, cudaDevAttrComputeCapabilityMinor, deviceId);
NppiSize roi = {1, 1};
static const Npp32f aTwist[3][4] = {
{ 0.299f, 0.587f, 0.114f, 0.5f},
{-0.168736f, -0.331264f, 0.5f, 128.5f},
{ 0.5f, -0.418688f, -0.081312f, 128.5f}
printf("\n%-26s R G B | Twist_IP3R | Twist_C3IR\n", "");
printf("%-26s | Y Cb Cr | Y Cb Cr\n", "TestCase");
printf("------------------------------------------------------------------\n");
for (const auto& tc : testCases) {
// --- nppiColorTwist32f_8u_IP3R_Ctx (planar, in-place) ---
Npp8u *dIP3R[3];
for (int i = 0; i < 3; i++) cudaMalloc(&dIP3R[i], 1);
cudaMemcpy(dIP3R[0], &tc.r, 1, cudaMemcpyHostToDevice);
cudaMemcpy(dIP3R[1], &tc.g, 1, cudaMemcpyHostToDevice);
cudaMemcpy(dIP3R[2], &tc.b, 1, cudaMemcpyHostToDevice);
NppStatus ip3rStatus = nppiColorTwist32f_8u_IP3R_Ctx(dIP3R, 1, roi, aTwist, nppCtx);
ASSERT_EQ(ip3rStatus, NPP_SUCCESS) << "IP3R failed for " << tc.name;
uint8_t tIP3Ry = 0, tIP3Rcb = 0, tIP3Rcr = 0;
cudaMemcpy(&tIP3Ry, dIP3R[0], 1, cudaMemcpyDeviceToHost);
cudaMemcpy(&tIP3Rcb, dIP3R[1], 1, cudaMemcpyDeviceToHost);
cudaMemcpy(&tIP3Rcr, dIP3R[2], 1, cudaMemcpyDeviceToHost);
for (int i = 0; i < 3; i++) cudaFree(dIP3R[i]);
// --- nppiColorTwist32f_8u_C3IR_Ctx (packed, in-place) ---
uint8_t hC3IR[3] = {tc.r, tc.g, tc.b};
Npp8u *dC3IR;
cudaMalloc(&dC3IR, 3);
cudaMemcpy(dC3IR, hC3IR, 3, cudaMemcpyHostToDevice);
NppStatus c3irStatus = nppiColorTwist32f_8u_C3IR_Ctx(dC3IR, 3, roi, aTwist, nppCtx);
ASSERT_EQ(c3irStatus, NPP_SUCCESS) << "C3IR failed for " << tc.name;
uint8_t tC3IRy = 0, tC3IRcb = 0, tC3IRcr = 0;
cudaMemcpy(&tC3IRy, dC3IR + 0, 1, cudaMemcpyDeviceToHost);
cudaMemcpy(&tC3IRcb, dC3IR + 1, 1, cudaMemcpyDeviceToHost);
cudaMemcpy(&tC3IRcr, dC3IR + 2, 1, cudaMemcpyDeviceToHost);
cudaFree(dC3IR);
printf("%-26s %3d %3d %3d | %3d %3d %3d | %3d %3d %3d\n",
tc.name, tc.r, tc.g, tc.b,
tIP3Ry, tIP3Rcb, tIP3Rcr,
tC3IRy, tC3IRcb, tC3IRcr);
