There are different output data of rotate function between nppiRotate(Npp of cuda) and ippiRotate(Ipp of intel) ?
hello everyone, please help me!
I have problem about convert ippiRotate_32f_C1R function(using Ipp library of intel) to nppiRotate_32f_C1R function(using Npp library of Cuda).
Two function read same input data, but output data are different at fist row.
With config:
int angle = -90;
double xShift = lSrcYLength - 1;
double yShift = 0;
Input data:
pflSrc[64] = {
1, 2, 3, 4,
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16,
17, 18, 19, 20,
21, 22, 23, 24
Output data:ippiRotate_32f_C1R
pflRes[6
4] = {
19, 13, 7, 1,
20, 14, 8, 2,
21, 15, 9, 3,
22, 16, 10, 4,
23, 17, 11, 5,
24, 18, 12, 6
Output data: nppiRotate_32f_C1R
pflResCuda[6*4] = {
0, 0, 0, 1,
20, 14, 8, 2,
21, 15, 9, 3,
22, 16, 10, 4,
23, 17, 11, 5,
24, 18, 12, 6
I had to try test with different config to give same output data, but only angle = -90 if wrong output data.
I use cuda version 6.0 and intel parallel studio 2011.
Thanks for help,
TaiNN
Refer to source code as bellow:
  • file main.cpp
#include "stdio.h"
#include "stdlib.h"
#include <cufft.h>
#include <cuda.h>
#include <string.h>
#include "C:\Program Files (x86)\Intel\Parallel Studio 2011\Composer\ipp\include\ipp.h"
#include "C:\Program Files (x86)\Intel\Parallel Studio 2011\Composer\ipp\include\ippi.h"
#include "C:\Program Files (x86)\Intel\Parallel Studio 2011\Composer\ipp\include\ippm.h"
#include "headerFile.h"
int  Rotate_1Slice(
		float*        pflSrc,
		float*	      pflRes,
		long          lSrcXLength,
		long          lSrcYLength
int main()
	long          lSrcXLength = 6;
	long          lSrcYLength = 4;
	int size = lSrcXLength * lSrcYLength;
	//init input data
	float		  pflSrc[6*4] = {
					     1, 2, 3, 4,
					     5, 6, 7, 8,
					     9, 10, 11, 12,
					     13, 14, 15, 16,
					     17, 18, 19, 20,
					     21, 22, 23, 24
	float		  pflRes[6*4] = {0};
	float		  h_pflSrcCuda[6*4] = {0};
	float		  h_pflResCuda[6*4] = {0};
	memcpy(h_pflSrcCuda, pflSrc, size*sizeof(float));
	printf("-----Input Matrix: pflSrc-----\n");
	show(pflSrc, lSrcXLength, lSrcYLength);
	//--------------------Ipp of intel-----------------------
	Rotate_1Slice
		pflSrc,
		pflRes,
		lSrcXLength,
		lSrcYLength
	printf("-----Result ippiRotate_32f_C1R function(Ipp of intel)-----\n");
	show(pflRes, lSrcXLength, lSrcYLength);
	//--------------------Cuda--------------------
	Rotate_1SliceCuda(
		h_pflSrcCuda,
		h_pflResCuda,
		lSrcXLength,
		lSrcYLength
	printf("-----Result nppiRotate_32f_C1R function(Npp of Cuda)-----\n");
	show(h_pflResCuda, lSrcXLength, lSrcYLength);
	printf("-----Compare data-------\n");
	if(CompareMatrix(pflRes, h_pflResCuda,size))
		printf("Difference data!\n");
	else
		printf("Same data!\n");
	return 0;
 int  Rotate_1Slice(
		float*	      pflSrc,
		float*	      pflRes,
		long          lSrcXLength,
		long          lSrcYLength
	IppStatus ippStatus;
	int    angle  = -90;
	double yShift = 0;
	IppiRect srcROI = { 0 , 0 , lSrcXLength , lSrcYLength };
	IppiRect resROI = { 0 , 0 , lSrcYLength , lSrcXLength };
	IppiSize size = {lSrcXLength,lSrcYLength};
	int sliceSize = lSrcXLength * lSrcYLength;
	ippStatus = ippiRotate_32f_C1R( pflSrc ,
									size ,
									lSrcXLength * sizeof(float) ,
									srcROI ,
									pflRes,
									lSrcYLength * sizeof(float) ,
									resROI ,
									angle,
									xShift , yShift ,
									IPPI_INTER_NN );
	if(ippStatus != ippStsNoErr)
		printf("Error! call ipp function\n");
	return 0;
 //Utilities function
 bool CompareMatrix(float *ori, float *mod, int size)
	bool result = false;;
	for(int i = 0; i < size; i++)
		if(ori[i] != mod[i])
			printf("Difference pixel %0.1f <-> %0.1f\n", ori[i], mod[i] );
			result = true;
	return result;
 void show(float *data, int row, int col)
	for(int i = 0; i < row; i++)
		for(int j = 0; j < col; j++)
			printf("%0.1f	",data[j + i*col] );
		printf("\n");
  • file Rotate_1SliceCuda.cu
#include <cuda_runtime_api.h>
#include <cuda.h>
#include <nppi.h>
#include<stdio.h>
int Rotate_1SliceCuda
		float*		  pflSrcCuda,
		float*		  pflResCuda,
		long          lSrcXLength,
		long          lSrcYLength
	NppStatus status;
	int sizeByte = lSrcXLength * lSrcYLength * sizeof(float);
	float *dev_pflSrc = NULL;
	float *dev_pflRes = NULL;
	cudaMalloc((void**)&dev_pflSrc, sizeByte);
	cudaMalloc((void**)&dev_pflRes, sizeByte);
	/* Transfer data from host to drive */
	cudaMemcpy(dev_pflSrc, pflSrcCuda, sizeByte, cudaMemcpyHostToDevice);
	cudaMemcpy(dev_pflRes,  pflResCuda, sizeByte, cudaMemcpyHostToDevice);
	int    angle  = -90;
	double yShift = 0;
	NppiRect srcROI = { 0 , 0 , lSrcXLength , lSrcYLength };
	NppiRect resROI = { 0 , 0 , lSrcYLength , lSrcXLength };
	NppiSize size = {lSrcXLength,lSrcYLength};
	status = nppiRotate_32f_C1R( dev_pflSrc ,
									size ,
									srcROI ,
									dev_pflRes ,
									resROI ,
									angle,
									xShift , yShift ,
									NPPI_INTER_NN );
	if(status != 0)
		printf("Error! call nppi function\n");
	/* Transfer data to host*/
	cudaMemcpy(pflResCuda, dev_pflRes, sizeByte, cudaMemcpyDeviceToHost);
	cudaFree(dev_pflSrc);
	cudaFree(dev_pflRes);
	return 0;
  • file HeaderFile.h
		float*		  pflSrcCuda,
		float*		  pflResCuda,
		long          lSrcXLength,
		long          lSrcYLength
void testRoate();
void show(float *data, int row, int col);
bool CompareMatrix(float *ori, float *mod, int size);
hello everyone,
I have description problem in picture. Let image with size 4 x 4. refer link:[url]http://www.upsieutoc.com/image/3UyZQ[/url]
Result nppiRotate_32f_C1R function isn’t correct.
I think, the problem can be bug of Npp library. please help me.
Thanks,
I am not familiar with this NPP functionality. I believe in general it is a correct assumption that NPP functions are supposed to be equivalent to the NPP functions of the same (except for the prefix) name. If you are using CUDA 8.0 and are quite certain that the problem is with NPP rather than your code (a common mistake when using NPP is an incorrect specification of the ROI), you should feel free to file a bug with NVIDIA. The bug reporting form is linked from the CUDA registered developer website.
@njuffa: Your suggestion seems to be good :D.
However, I’ve tried to produce output with CUDA 8.0. The result is same as CUDA6.0.
[url]https://goo.gl/photos/Dxd2F3PfLfjipGsi8[/url]
The reason I referenced CUDA 8.0 is because bug reports are only of interest if they are against the latest version. I did not mean to imply that the behavior is different between CUDA versions. IF you use CUDA 8.0 AND you experience broken code THEN file a bug report.
Thank njuffa in advance, and support TamNT27.
I wait for answer to correct this problem.
Supporter of nvidia in here? please help me.
I would not expect that the NPP and IPP rotation routines give exactly the same result (especially on the border). The same applies for resize routines and warping routines (either NPP or NPP). Reasons ?
Minor things willchange the results slightly. Like the used border mode. Like where the people which implemented the routine are putting the center of the coordinate system (is it the center of the upperleft pixel or the upperleft corner of the upperleft pixel ? ). Like the rounding mode (up/down/nearest). For bicubic interpolation (which you do not use), there is another factor as there are different flavours of bicubic interpolation (catmull-rom, mitchell-netravali, …).
Actually, even when only one library like the IPP, on using the IPP routine we noticed slight differences in the result of the ‘resize’ routine from one IPP version (6.1) to a newer one (8.2).
So for all kinds of geometric operations you shouldn’t expect a 100% identical result.
Furthermore, i would recommend to use bilinear instead of nearest-neighbor interpolation.
And if you are doing a 90 degree rotate always - that is i think a transposition and can be done in a more direct way.
Thanks HannesF99 for your suggest,
In here only change position in image, not value.So I think it give exactly the same result.
Example: let image with size = 4 x 4,
to calculate rotates an image around (0, 0) by specified angle(-90) + shifts it(3, 0)
input=
1, 2, 3, 4,
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16
  • Following theory about rotate + ship:
    output =
    13, 9, 5, 1,
    14, 10, 6, 2,
    15, 11, 7, 3,
    16, 12, 8, 4
  • Using ippiRotate_32f_C1R function(Ipp library of intel), there is output data is correct as same theory.
  • Using NppiRotate_32f_C1R function(Npp library of CUDA), there is output data isn’t correct.
    output =
    aa, aa, aa, 1,
    14, 10, 6, 2,
    15, 11, 7, 3,
    16, 12, 8, 4
    position have value = aa are wrong value.
    I think logic of rotate (NPP library) wrong.
    Thank,
