I am programming an application in which i have to rotate an image by a set angle and then display the image. Following is the logic of the code I am using:
Allocate memory for data (image) in the device.
CudaMemcpy data to the device .
Call nppirotate function with the below parameters.
//allocate memory for input image in device cudaMalloc((void**)&outImage, rows * cols * sizeof(unsigned char)); cudaMalloc((void**)&dev_im1, rows * cols * sizeof(unsigned char)); cudaMalloc((void**)&dev_im_rotate, rows * cols * sizeof(unsigned char)); cudaMalloc((void**)&dev_im_rotate_host, rows * cols * sizeof(unsigned char)); int angle = 30; //copy images from host to device cudaError_t errr = cudaMemcpy(dev_im1, inImage, rows * cols * sizeof(unsigned char), cudaMemcpyHostToDevice); cout << "Error is" << cudaGetErrorString(errr) << errr << endl; NppiSize size = {800,600}; NppiRect rect_shift = {0,0,850,650}; NppiRect rect = {0,0,800,600}; NppStatus status = nppiRotate_8u_C1R ((Npp8u*) dev_im1, size, sizeof(Npp8u) * cols, rect, (Npp8u*) dev_im_rotate, sizeof(Npp8u) * cols, rect_shift, 180*angle/M_PI, 0, 0, NPPI_INTER_LINEAR); cout << "error is" << status << endl;
The output I am getting is error is-14. However, I am unsure about the cause of the same. Also, I want to use bilinear for interpolating the pixels, but I dint find an option in the library to use bilinear. Will it make a difference if I use Linear Interpolation.
The size of my input image is 800 by 600 pixels and grayscale. The error is a NPP_MEMSET_ERR.
