- GPU: NVIDIA RTX A6000
- Ubuntu: 20.04
An error occurs when I run sudo apt-get -y install cuda following the official guide for cuda-11.3:
A modprobe blacklist file has been created at /etc/modprobe.d to prevent Nouveau
from loading. This can be reverted by deleting the following file:
/etc/modprobe.d/nvidia-graphics-drivers.conf
A new initrd image has also been created. To revert, please regenerate your
initrd by running the following command after deleting the modprobe.d file:
`/usr/sbin/initramfs -u`
*** Reboot your computer and verify that the NVIDIA graphics driver can ***
*** be loaded. ***
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Loading new nvidia-465.19.01 DKMS files...
Building for 5.15.0-101-generic
Building for architecture x86_64
Building initial module for 5.15.0-101-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-kernel-source-465.0.crash'
Error! Bad return status for module build on kernel: 5.15.0-101-generic (x86_64)
Consult /var/lib/dkms/nvidia/465.19.01/build/make.log for more information.
dpkg: error processing package nvidia-dkms-465 (--configure):
installed nvidia-dkms-465 package post-installation script subprocess returned error exit status 10
Setting up libcusolver-dev-11-3 (11.1.1.58-1) ...
Setting up cuda-cupti-11-3 (11.3.58-1) ...
dpkg: dependency problems prevent configuration of cuda-drivers-465:
cuda-drivers-465 depends on nvidia-dkms-465 (>= 465.19.01); however:
Package nvidia-dkms-465 is not configured yet.
dpkg: error processing package cuda-drivers-465 (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up cuda-cupti-dev-11-3 (11.3.58-1) ...
dpkg: dependency problems prevent configuration of cuda-drivers:
cuda-drivers depends on cuda-drivers-465 (= 465.19.01-1); however:
Package cuda-drivers-465 is not configured yet.
dpkg: error processing package cuda-drivers (--configure):
Setting up cuda-libraries-dev-11-3 (11.3.0-1) ...
dpkg: dependency problems prevent configuration of nvidia-driver-465:
nvidia-driver-465 depends on nvidia-dkms-465 (= 465.19.01-0ubuntu1); however:
dpkg: error processing package nvidia-driver-465 (--configure):
No apport report written because MaxReports is reached already
Setting up cuda-visual-tools-11-3 (11.3.0-1) ...
dpkg: dependency problems prevent configuration of cuda-runtime-11-3:
cuda-runtime-11-3 depends on cuda-drivers (>= 465.19.01); however:
Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-11-3 (--configure):
Setting up cuda-samples-11-3 (11.3.58-1) ...
Setting up cuda-command-line-tools-11-3 (11.3.0-1) ...
dpkg: dependency problems prevent configuration of cuda-demo-suite-11-3:
cuda-demo-suite-11-3 depends on cuda-runtime-11-3; however:
Package cuda-runtime-11-3 is not configured yet.
dpkg: error processing package cuda-demo-suite-11-3 (--configure):
Setting up cuda-documentation-11-3 (11.3.58-1) ...
dpkg: dependency problems prevent configuration of cuda-11-3:
cuda-11-3 depends on cuda-runtime-11-3 (>= 11.3.0); however:
cuda-11-3 depends on cuda-demo-suite-11-3 (>= 11.3.58); however:
Package cuda-demo-suite-11-3 is not configured yet.
dpkg: error processing package cuda-11-3 (--configure):
Setting up cuda-tools-11-3 (11.3.0-1) ...
dpkg: dependency problems prevent configuration of cuda:
cuda depends on cuda-11-3 (>= 11.3.0); however:
Package cuda-11-3 is not configured yet.
dpkg: error processing package cuda (--configure):
Setting up cuda-toolkit-11-3 (11.3.0-1) ...
Setting alternatives
update-alternatives: using /usr/local/cuda-11.3 to provide /usr/local/cuda (cuda) in auto mode
update-alternatives: using /usr/local/cuda-11.3 to provide /usr/local/cuda-11 (cuda-11) in auto mode
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for initramfs-tools (0.136ubuntu6.7) ...
update-initramfs: Generating /boot/initrd.img-5.15.0-101-generic
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.14) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Errors were encountered while processing:
nvidia-dkms-465
cuda-drivers-465
cuda-drivers
nvidia-driver-465
cuda-runtime-11-3
cuda-11-3
cuda
E: Sub-process /usr/bin/dpkg returned an error code (1)
I suspect the issue is that the NVIDIA RTX A6000 graphics card is not compatible with nvidia-driver-465 , thus preventing the installation of cuda-11.3.
Is this the reason? Thanks
