My Xorg.0.log is full of errors like this:
[ 37.627] (EE) NVIDIA(GPU-0): WAIT (2, 8, 0x8000, 0x00002390, 0x00003620)
[ 37.856] (EE) NVIDIA(0): The NVIDIA X driver has encountered an error; attempting to
[ 37.856] (EE) NVIDIA(0): recover...
And dmesg seems to contain more information:
[ 38.010652] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
[ 38.020849] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 38.474067] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 54.990358] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x81
[ 55.000554] nvgpu: 57000000.gpu fifo_error_isr:2605 [ERR] channel reset initiated from fifo_error_isr; intr=0x00000100
[ 98.815590] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
[ 98.825793] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 98.837968] ---- mlocks ----
I have attached full logs: dmesg.log (125.3 KB) Xorg.0.log (15.5 KB)
I have 2560x1440 monitor attached (actually it is 1440x2560 rotated with xrandr, I used suggestion by NVidia employee here 1440x2560 HDMI display not working to fix hdmi2.0.c and recompile the kernel; I did not do any other changes to the kernel).
After a while, Xorg freezes and uses about 100% CPU. Any ideas if this is hardware or software issue? The monitor works fine with NVidia card on my PC (GTX 2060 SUPER 8GB) and even with Raspberry Pi, so I guess monitor’s hardware is OK.
