Hello, I’m going to write a code that operates motor using jetson nano’s pwm.
Before starting the motor drive, I measured the waveform after writing the code with 50 Hz and duty 50% for the pwm test, and it came out as follows.
Hi, PWM signal is only for the control of motor which means it should be routed to a switch of motor. The waveform with motor seems show it has been affected by the motor.
