How to connect and program a simple mini servo motor with Jetson Nano GPIO
Hello everyone,
I recently connected a mini servo motor to pin 32 on my Jetson Nano in an attempt to control a robot. However, I am facing an issue where the motor is not responding to any signals. It seems like the motor is not receiving any signal from the GPIO pin.
I would appreciate any guidance or suggestions on how to successfully control a servo motor using GPIO on the Jetson Nano. I have checked the wiring and connections, but the motor still does not move.
If anyone has experience with controlling servo motors on the Jetson Nano or has encountered a similar issue, please share your insights or solutions. Any help or advice would be greatly appreciated.
Thank you in advance for your assistance.
Please check below threads to see if can help:
Running two simple DC motors (5 Amp) Forward and Backward in Jetson Nano - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
How to use servo and pwm motor libraries - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
