I tried to test the speed of 5G dongle module(MV31-W CINTERION) on Nvidia TX1 28.2.0.
The top download speed is about 275Mbps and upload is about 80Mbps,
However, testing on Windows 10(x64),
the top download speed is about 1128Mbps and upload is about 96Mbps.
Is this any ideas or suggestions to enhance the speed for 5G dongle.
Thank you.
Hi WayneWWW,
This 5G module is M.2 slot, but i use a board to transform M.2 into USB slot.
I didn’t enable the jetson_clocks for testing.
I’ll enable the script and try again.
Thanks for your help.
In the latter link from @Honey_Patouceul, ignore the “usb_port_owner_info=2”. The memory increase and removal of autosuspend are what might help. The autosuspend part is obvious and something many people here will end up needing, while changing memory would only be a problem if there were bandwidth overrun/underrun issues.
We also want to know if it is possible to use other usb device to test the speed on both your host and TX1 too.
For example, some ethernet dongle and see if the iperf result also has large gap between TX1 and host.
Currently, we don’t think this issue is due to usb bandwidth.
You could also try the 5G dongle on ubuntu host as a benchmark.
From tegrastats shown in IMG_0816.JPG, it looks like the performance is capped by CPU capability. The four CPUs are at max clocks with > 90% loading. Probably there are significant CPU executions in the speed test. Not sure if this is possible, but if there is a mode in the speed test which can take less CPU usage, maybe we can try the mode.
