The usage of cam_fsync_program_abs_start_value API to control camera fsync
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I called the API cam_fsync_program_abs_start_value to control camera fsync between multi Orin-X EVB. I inserted group ID 0 with absolute TSC clock value which I want to start fsync. But this API returned CAM_FSYNC_GROUP_NOT_FOUND (value -2).
What should I do to clear this issue? Does this have a condition to apply fsync start time?
Error String
The CAM_FSYNC_GROUP_NOT_FOUND (-2) is returned
Dear @chobr84 ,
I notice nvsipl_camera uses this API. Did you try the sample? May I know the camera module?
Dear @SivaRamaKrishnaNV
My SW is refered from nvsipl_camera application SW of nvidia. It’s not be refered nvsipl_sample.
The camera model which is show from nvsipl_camera SW are following models.
for valeo IMX728 cameras,
  • V1SIM728S1RU3120NB20_CPHY_x4
  • V1SIM728MPRU4120HD1_CPHY_x4
  • V1SIM728MPRU3030ND1_CPHY_x4
for valeo IMX623 cameras,
  • V1SIM623S5RU5195NC0_CPHY_x4
Or should I configure the dtsi file before flash to EVB?
path : /drive/drive-linux/kernel/source/hardware/nvidia/platform/t23x/automotive/kernel-dts/p3710/common/tegra234-p3710-0010.dtsi
            fsync-groups {
                    status = "disabled";
                    fsync-group@0 {
                            id = <0>;
                            status = "okay";
                            generators = <&gen0>, <&gen2>, <&gen3>;
                    fsync-group@1 {
                            id = <1>;
                            status = "okay";
                            generators = <&gen1>;
The status of fsync-groups is “disabled”. Should I change this to “okay”?
How I can find the valid range of group ID in parameter?
Best Regards
Bongrae Cho
I solve this issue.
The dtsi configuration was modified for Drive AGX Orin-X EVB. So the status of fsync-groups should be “okay” from “disabled”.
Then API return is OK.
