Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
A new feature in 6.0.8.1 appears to be the cam_fsync driver, which (assuming fsync-groups are enabled) creates a rising edge for camera synchronization with greater control than was previously possible. I have used this new driver and library and found it to be functional, however, I note that there doesn’t appear to be a simple method of stopping the fsync-group once it has been started - attempts to run nvsipl_camera with the -F flag set after it has been run successfully once results in it failing out with dmesg reporting that the fsync-group isn’t idle, there is no easy function call in NvCamFsync.h (included in the updated version of nvsipl_camera) to stop the group, the ioctl call in cam_fsync.c for which the function cam_fsync_program_abs_start_value is a convenient alias doesn’t have any other ioctl-compatible calls to stop or reconfigure the fsync-group, the only way it appears to reset the fsync-group is to rmmod and modprobe the cam_fsync driver or restart the Drive AGX entirely, which is a bit scorched-earth. Does NVIDIA have a recommendation on how to stop and restart fsync-groups?
