Software Version
DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.2.10884
other
Host Machine Version
The --nvsci option for the nvsipl_camera test program stopped working in the DRIVEOS 6.0.6 release. This option does work on 6.0.5. Using 6.0.6 without the --nvsci flag the nvsipl_camera program appears to work normally, as seen here:
root@ep:camera# ./nvsipl_camera -c "IMX728_RGGB_CPHY_x4" --showfps -d 1 -m "0x0110 0x0000 0x0000 0x0000" --nvsci
MAX96712: Revision 5 detected
MAX96712 Link 1: PHY optimization was enabled
MAX96712 Link 2: PHY optimization was enabled
MAX96717: Revision 4 detected!
Sensor IMX728 Rev 3 RGGB detected!
nvsipl_camera: Opened NITO file for module "IMX728_RGGB", file name: "/usr/share/camera/IMX728_RGGB.nito"
Enter 'ld' to list display-able outputs.
Enter 'e' followed by group ID and display ID to enable display for specific camera group
Enter 'les' followed by sensor ID to enable LED
Enter 'lds' followed by sensor ID to disable LED
Enter 'dl' followed by sensor ID to disable the link
Enter 'el' followed by sensor ID to enable the link without module reset
Enter 'elr' followed by sensor ID to enable the link with module reset
Enter 'cm' to check the module availabilty
Enter 'q' to quit the application
nvsipl_camera: ERROR: NvSciSyncFenceWait failed. nvSciStatus: 256
Output
Sensor1_Out1 Frame rate (fps): 2.99989
Sensor1_Out2 Frame rate (fps): 2.99989
Sensor1_Out3 Frame rate (fps): 2.99989
Sensor2_Out1 Frame rate (fps): 2.99989
Sensor2_Out2 Frame rate (fps): 2.99989
Sensor2_Out3 Frame rate (fps): 2.99989
Output
Sensor1_Out1 Frame rate (fps): 0
Segmentation fault
root@ep:camera#
Pipeline: 1 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 1 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 1 ISP Output: 2 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 2 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 2 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 2 ISP Output: 2 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Output
Sensor1_Out1 Frame rate (fps): 28.9988
Sensor1_Out2 Frame rate (fps): 28.9988
Sensor1_Out3 Frame rate (fps): 28.9988
Sensor2_Out1 Frame rate (fps): 28.9988
Sensor2_Out2 Frame rate (fps): 28.9988
Sensor2_Out3 Frame rate (fps): 28.9988
Output
Sensor1_Out1 Frame rate (fps): 29.999
Sensor1_Out2 Frame rate (fps): 29.999
Sensor1_Out3 Frame rate (fps): 29.999
Sensor2_Out1 Frame rate (fps): 29.999
Sensor2_Out2 Frame rate (fps): 29.999
Sensor2_Out3 Frame rate (fps): 29.999
... continues to stream video
