Software Version
[V] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[V] Linux
QNX
other
Hardware Platform
[V] DRIVE AGX Orin Developer Kit (940-63710-0010-D00)
other
SDK Manager Version
1.9.3.10904
[V] other
Host Machine Version
[V] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I tried to run the nvsipl_camera app according to the guideline for Sensing SG8-IMX728C-FPDLinkIV with the following command; But it showed an error.
sudo ./nvsipl_camera --platform-config "IMX728_FPDLINK_RGGB_CPHY_x4" --link-enable-masks "0x0001 0x0000 0x0000 0x0000" -d 1
nvsipl_camera: ERROR: GetSyncObj failed. status: 10
nvsipl_camera: ERROR: Compositor: UnregisterNvSciSyncObjs failed
I thought that the Orin supports this camera considering the first item in Supported Sensors | NVIDIA Docs
Could you advise if the Orin supports the camera?
There was a different error log when I connected the DP port to a monitor.
seunghyun@tegra-ubuntu:/opt/nvidia/drive-linux/samples/nvmedia/nvsipl/test/camera$ sudo ./nvsipl_camera --platform-config "IMX728_FPDLINK_RGGB_CPHY_x4" --link-enable-masks "0x0001 0x0000 0x0000 0x0000" -d 1
Pipeline: 0 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 0 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 0 ISP Output: 2 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
raised PROGRAM_ERROR : unhandled signal
Best regards,
