Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other - 1.9.3.10904
Host Machine Version
other
Test properties:
- local with a monitor, keyboard, and mouse connected to the Orin device
- Cameras connected to link A
Hi, I am testing the nvsipl camera application and am trying to display the live camera feed. My command to run the application is:
sudo ./nvsipl_camera -c “F008A120RM0AV2_CPHY_x4” --link-enable-masks “0x0001 0x0000 0x0000 0x0000” -d 1
I am getting the same error on this forum post wfdCreateDevice failed on drive agx orin
I tried the solution that was:
However, this turns off the desktop on the local monitor, so I cannot run the nvsipl camera application after running these commands.
I tried to use ssh to run the nvsipl camera application after stopping gdm, but I got the following error:
MAX96712: Revision 5 detected
MAX96722: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96712 Link 1: PHY optimization was enabled
MAX96712 Link 2: PHY optimization was enabled
MAX96712 Link 3: PHY optimization was enabled
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
nvsipl_camera: ERROR: GetSyncObj failed. status: 10
nvsipl_camera: ERROR: Compositor: UnregisterNvSciSyncObjs failed
Illegal instruction
Do you have any info on how to export the video to the display on nvsipl camera? The other command line options are working correctly. Thanks!
