Nvsipl_camera display function cannot work on the default linux 6040
Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other 940-63710-0010-200
SDK Manager Version
1.9.0.10816
other
Host Machine Version
other
dear nv experts:
I receive the news devkit-p3710 arrive. I see that devkit have the default the dos version is that cat /etc/nvidia/version-ubuntu-rootfs.txt
6.0.4.0-31006010
so I try to run the nvsipl_camera and ./nvsipl_camera -c β€œV1SIM623S3RU3200NB20_CPHY_x4” -m β€˜0x0001 0x0000 0x0000’ --showfps -0 -1 --disableISP2Output -R
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96717F : Revision 4 detected!
Sensor IMX623 Rev 8 RGGB detected!
Enter β€˜les’ followed by sensor ID to enable LED
Enter β€˜lds’ followed by sensor ID to disable LED
Enter β€˜dl’ followed by sensor ID to disable the link
Enter β€˜el’ followed by sensor ID to enable the link without module reset
Enter β€˜elr’ followed by sensor ID to enable the link with module reset
Enter β€˜cm’ to check the module availabilty
Enter β€˜q’ to quit the application
Output
Sensor0_Out0 Frame rate (fps): 28.499
but if I add the -d 1 . it report the error info:
./nvsipl_camera -c β€œV1SIM623S3RU3200NB20_CPHY_x4” -m β€˜0x0001 0x0000 0x0000’ --showfps -1 --disableISP2Output -d 1
nvsipl_camera: ERROR: wfdCreateDevice failed
nvsipl_camera: ERROR: Unable to initialize IDisplayManager
nvsipl_camera: ERROR: Compositor: InitDisplay failed
nvsipl_camera: ERROR: Compositor initialization failed. status: 4
nvsipl_camera: ERROR: NvMedia2DGetComposeParameters failed. nvmStatus: 1
nvsipl_camera: ERROR: Compositor: Deinit failed
nvsipl_camera: ERROR: GetSyncObj failed. status: 10
nvsipl_camera: ERROR: Compositor: UnregisterNvSciSyncObjs failed
Dear @binbin.ding,
Please check wfdCreateDevice failed on drive agx orin if it helps?
yes, it hepls me to solved. thanks for your support.
