The camera can't get the image
Software Version
[*] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.9.1.10844
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi sir
we run the ./nvsipl_camera, but it can’t get the images from the camera. It reports as below:
ChanselFault:0x00000200
Current line in frame [31:16]:0
The attachment is the detail log, please help check this is why?
camera.log (72.0 KB)
the detailed log
Dear @sunjiandong,
Could you share camera module details and complete command?
Could you test with other supported camera modules if you have any?
We have supported camera modules at https://developer.nvidia.com/drive/ecosystem-orin#camera
Hi sir
The sensor is LI-OX08B40, and it is use MAX9295 as Ser, And the module output format is YUV
The command is below:
sudo ./nvsipl_camera --platform-config “LI-OX08B40-VCSEL-GMSL2-60H_DPHY_x4” --link-enable-masks “0x0000 0x0000 0x0001 0x0000” --disableISP0Output --disableISP1Output --disableISP2Output --enableRawOutput --writeFrames 1 --skipFrames 100 --filedump-prefix=“ox08b40.yuv” -v 5
You may want to check our documentation for supported camera modules as I don’t see the LI-OX08B40 listed there.
Hi sir
Yes, this camera is not in the support list. But we need use LI-OX08B40 for our project.
So can you give us any suggestions from the log and sensor information?
I understand that the camera you need to use for your project is not in the support list. However, custom camera modules fall outside of the scope of this forum. It’s best to discuss your requirements with your NVIDIA representative to explore the options available to you.
Thank you for your understanding.
@VickNV
Can you help check whether the SDK 6.0.5 support the YUV?
We’ll check with our team and update you here. Thanks.
Hi sir
Is there any update?
All camera vendors provide modules with integrated signal processing, but we do not list or track any of the YUV camera suppliers might have. Although some vendors’ modules are already compatible with DriveOS 6.0.5, we are not advertising this publicly through DevZone. Please contact the camera module vendors directly to understand this.
