Unsupported camera module vendor LI-OV2311-VCSEL-GMSL2-55H log but camera works
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Successfull camera init → I can get an image from camera but during initialization there is an error :
[10-09-2023 10:15:18] CameraClient: using NITO found at /usr/share/camera/LI-OV2311-VCSEL-GMSL2-55H.nito
[10-09-2023 10:15:18] Unsupported camera module vendor LI-OV2311-VCSEL-GMSL2-55H
I contacted leopard imaging, they are claiming we should seek support from nvidia regarding this issue.
Error String
Logs>
[10-09-2023 10:15:17] Found driver: camera.gmsl
[10-09-2023 10:15:17] CameraBase: pool size set to 8
[10-09-2023 10:15:17] SensorFactory::createSensor() → camera.gmsl.master,
[10-09-2023 10:15:17] Found driver: camera.gmsl.master
[10-09-2023 10:15:18] CameraMaster::parseDevBlock Getting device info list.
[10-09-2023 10:15:18] CameraClient, setting isp-mode to yuv420-uint8
[10-09-2023 10:15:18] CameraClient, isp-mode set to yuv420-uint8
[10-09-2023 10:15:18] devBlock: 0 Slave = 0 Interface = csi-c Camera_name = LI-OV2311-VCSEL-GMSL2-55H Link = 1 GroupInit = 0
[10-09-2023 10:15:18] Camera Match Name: LI-OV2311-VCSEL-GMSL2-55H Description: OV2311, MAX9295, 60FPS linkIndex: 4294967295 serInfo.Name: MAX96717F
[10-09-2023 10:15:18] Authentication is disabled for camera LI-OV2311-VCSEL-GMSL2-55H
[10-09-2023 10:15:18] Not an EEPROM supported camera LI-OV2311-VCSEL-GMSL2-55H
[10-09-2023 10:15:18] Client, Setting up information for camera ID 0
[10-09-2023 10:15:18] Client, successfully found info for camera ID 0 bound to id 0
[10-09-2023 10:15:18] ImageStreamer(NvMedia → CUDA)
[10-09-2023 10:15:18] CameraClient: CVARS not registered for camera: LI-OV2311-VCSEL-GMSL2-55H
[10-09-2023 10:15:18] SyncDriver: GPU device available, enabling CUDA sync
[10-09-2023 10:15:18] SyncDriver: enableCUDAPresync, object successfully created
~0822
Dear @ext.mateusz.pedzik ,
Did you check running sample_camera? Could you share full command and logs?
