Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
We have a digital twin of the camera module F008A120RM0A and we are trying to use the ./nvsipl_camera example
When we try to run the command
./nvsipl_camera --platform-config "F008A120RM0A_CPHY_x4" --link-enable-masks "0x0001 0x0000 0x0000 0x0000" -d 0 -w 1 --enableRawOutput --disableISP0Output --disableISP1Output
We get the following error
Platform configuration name: F008A120RM0A_CPHY_x4
Verbosity level: 4
Raw output: enabled
ISP0 output: disabled
ISP1 output: disabled
Disabled FPS logging
Disabled Metadata logging
Disabled automatic recovery
Disabled NvSci
Disabled profiling
Disabled initialization profiling
Display ID: 0
Display window ID: 1
Display window Depth: 0
Display window position: 0 0 0 0
Disabled Secondary mode
Disabled retrieving/displaying NITO Metadata
nvsipl_camera: Setting up signal handler
nvsipl_camera: Getting platform configuration for F008A120RM0A_CPHY_x4
nvsipl_camera: Setting link masks
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 91: ApplyMask: block:0 enabled
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 100: ApplyMask: module:0 enabled
nvsipl_camera: Creating camera master
nvsipl_camera: Setting up master
nvsipl_camera: Initializing compositor
nvsipl_camera: Creating consumers
Platform:
Platform configuration: F008A120RM0A_CPHY_x4
Platform configuration description: F008A120RM0A 24BIT RGGB module in 4 lane CPHY mode
CSI Port: 2
I2C Device 0
Deserializer Name:MAX96712
Description: Maxim 96712 Aggregator
I2C Address: 0x29
CameraModule on link 0
Description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295
Serializer Name: MAX9295
Address: 0x62
Sensor Name: AR0820
Description: OnSemi AR0820 Sensor
Address: 0x10
EEPROM Name: N24C64
Address: 0x54
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 67: SetPlatformCfg: Create device block control
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 75: SetConfig: Create device block
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 88: SetConfig: Set device block config
Main: CDevBlkDriverLibs.cpp: 116: FindFirstLibPath: Checking "/usr/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 116: FindFirstLibPath: Checking "/usr/lib/nvsipl_drv" for drivers
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Loading library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 193: LoadDriversLibraries: Opening driver library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMDeserializerFactory.cpp: 54: LoadDeserializerDriver: Loading Deserializer driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: CDevBlkDriverLibs.cpp: 49: CDevBlkDriverLibs: Driver libraries are already loaded
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_8M" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_AR0820" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_IMX390" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_OV2311" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_T_2M" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_T_YUV8_2M" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "Constellation_T_8M" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "OV2311_C_3461" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "AR0144P" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_RCCB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RCCB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_RCCB_BINNING" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_RCCB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RCCB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_RCCB_BINNING" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030BM0A_RGGB_BINNING" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120BM0A_RGGB_BINNING" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A070BM0A_24BIT_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A030RM0A" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A070RM0A" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120RM0A" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "F008A120RM0A_SIDE" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390_RCCB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390RGGBE3_200FOV_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390RGGBE5_200FOV_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390RGGBMP_200FOV_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "IMX390_C_3461_F200_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "AR0820C120FOV_24BIT_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "AR0820C70FOV_24BIT_RGGB" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "VC0820C120R24" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "VC0820C070R24" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "MAX96712TPG" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "MAX96712TPG_YUV_8" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 118: LoadDriver: Loading CameraModule driver from library "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "SF3324" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: CNvMCameraModuleFactory.cpp: 160: LoadDriver: Mapping module name "SF3325" to module driver "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
nvsipl_camera: Creating consumer for output:0 of sensor:0
nvsipl_camera: Register with compositor for output:0 of sensor:0
nvsipl_camera: Compositor: Registered output:0 from link:0 of quad: 0 as id:0
nvsipl_camera: Consumer initialization for output:0 of sensor:0
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 427: Init: Initializing device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 164: Init: Creating worker thread for block:0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 31: ThreadCreate: Creating thread:DEVBLK_WORKER_0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 171: Init: Created worker thread for block:0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 124: WorkersDoAction: All worker threads starting action:1
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 131: m_FuncStatic: Thread created
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 118: ThreadSetName: Setting thread name:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 146: m_Func: Running thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 149: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: CNvMMax96712.cpp: 180: DoInit: Check deserializer is present
MAX96712: Revision 2 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 187: DoInit: Set deserializer defaults
MAX96712 Rev 2: Link 0: Tx amplitude 0x28, 0x68, 0xb3, 0x72, 0xd2
MAX96712 Rev 2 manual adaptation on the link 0 (31)
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 2368
Module_id 30 Severity 2 : MAX96712: GMSL2 link lock not detected on link 0
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/CNvMMax96712.cpp 190
Module_id 30 Severity 2 : MAX96712: MAX96712SetDefaults failed with NvMedia error 7
Module_id 30 Severity 2 : src/devblk/common/ddi/CNvMDevice.cpp 68
Module_id 30 Severity 2 : Driver failed Init() call 127
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 701
Module_id 30 Severity 2 : Deserializer init failed with SIPL error 127
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 435: ThreadFunc: Device block init failed(7f)
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 144
Module_id 30 Severity 2 : Device block action failed for block (action, block) 10
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 152: WorkersDoAction: All worker threads finished action:1
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 180
Module_id 30 Severity 2 : Failed to initialize device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 127
nvsipl_camera: Queue timeout
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 705: Deinit: Deinit() call in wrong state
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 994: DeinitPipelines: Pipeline deinit failed for pipeline:0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1013: Deinit: Deinit device block in CNvMCamera::Deinit()
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 124: WorkersDoAction: All worker threads starting action:4
Module_id 30 Severity 2 : src/devblk/fusa/cameramodule/common/utils/pwr_utils.cpp 464
Module_id 30 Severity 2 : nvccp_set_aggreg_pwr_off failed with status 2
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/CNvMMax96712.cpp 566
Module_id 30 Severity 2 : MAX96712: CNvMMax96712::DoSetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/ddi/DeserializerIF/CNvMDeserializer.cpp 42
Module_id 30 Severity 2 : CNvMDeserializer::SetPower failed with SIPL error 127
Module_id 30 Severity 2 : src/devblk/common/core/CNvMDeviceBlock.cpp 845
Module_id 30 Severity 2 : Deserializer SetPower failed with SIPL error 127
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 456: ThreadFunc: Device block deinit failed(7f)
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 171: m_Func: Exiting thread:DEVBLK_WORKER_0
Module_id 30 Severity 2 : Device block action failed for block (action, block) 40
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 152: WorkersDoAction: All worker threads finished action:4
Module_id 30 Severity 2 : src/core/CNvMDeviceBlockMgr.cpp 244
Module_id 30 Severity 2 : Failed to deinit device blocks
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 53: ThreadQuit: Quitting thread:DEVBLK_WORKER_0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 63: ThreadQuit: Waiting for thread:DEVBLK_WORKER_0 to end
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation.so"
Main: CDevBlkDriverLibs.cpp: 72: ~CDevBlkDriverLibs: dlclose
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_constellation_t.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0144.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_imx390_c_3461.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_b_3461.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 70: ~CDevBlkDriverLibs: Closing library: "/usr/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0231.so"
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1016: Deinit: DeviceBlock manager fails to deinit
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 49: ~CNvMCamera: CNvMCamera object fails to deinit
Especially the steps after MAX96712 Rev 2 manual adaptation on the link 0 (31) have failed and we also observe the error MAX96712: GMSL2 link lock not detected on link 0.
Could you please let us know the reason for this issue?
Thanks in advance for your support!
Best regards,
Roshan
