We’re using SONY’s IMX390 with our Drive AGX and we have recently started seeing the following error when running our camera pipline using SIPL framework:
nvmedia: ERROR: MAX96712: Link 0: GMSL2 decoding error (1)
libnvsipl.so: CNvMCamera.cpp: 309: OnLinkError: DeviceBlock 0 encountered link errors. Link Mask:1
Do you have any information on what could cause this and how we can troubleshoot the issue?
Thanks,
B.
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version => 5.1.6.1-16902563
other
Dear @bogdan0kg3v ,
Could you confirm if it is a customer DRIVE OS build?
Could you check with other camera module, fakra Coax Cable and Quad Camera Breakout Cable (which is working on another port) and try it on the port.
Exactly. Everything is fine on the other ports and boards with the same setup. The whole setup was working properly with all the cameras, but at some point one of the cameras started failing with the error that I’ve shared.
Could it be that there a hardware issue with the board?
Dear @bogdan0kg3v,
Could you share the port, camera and used command to double check?
Any suggestion how we can confirm the HW issue?
As you said your Sony IMX390 camera is working on all other ports with the same quad cable on same target, could you check with other camera models like sekonix on the same port to confirm if it is HW issue(issue with port).
Please check the issue from both Tegras and share feedback.
Dear @bogdan0kg3v ,
We notice similar issue couple of month ago at Defect Nvidia Drive AGX . Is this a new issue? We did not hear any update on that thread.
Dear @bogdan0kg3v ,
Could you check connecting four SF3324/25 cameras to that port and run nvmimg_cap sample with relevant configuration(SF33(24|25)-TRIO-(AB|CD|EF|GH ) set and share log
