Hi all,
we’re seeing issues with one of the Drive AGX Developer Kits, where we receive the output below only for a single port of a Drive AGX developer Kit. We think that the developer board is defective, as all the other potential components were already exchanged, and with a second Drive AGX Developer Kits exactly the same setup works, including completely reflashing it to make sure the SW configuration matches 100 %.
Would be great if you could suggest the next steps here!
Best regards,
Sebastian
nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
MAX96712: Revision 2 detected
MAX9295: Revision 8 detected!
Sensor IMX390 Rev 0 RGGB detected!
Reading camera_overrides.isp override file
nvmedia: ERROR: MAX96712 ERRB was Set
nvmedia: ERROR: MAX96712: Link 0: GMSL2 decoding error (255)
EngineStatusError (2), Detailed Error Code: 00000100 at StreamId:5 vcId:0 CSIFrameId:0
nvmedia: ERROR: IMX390WriteRegister: sensor write failed: 0x8, length 1
nvmedia: ERROR: MAX96712: Link 0: GMSL2 decoding error (1)
libnvsipl.so: CNvMCamera.cpp: 309: OnLinkError: DeviceBlock 0 encountered link errors. Link Mask:1
nvmedia: ERROR: MAX96712: Link 0: GMSL2 idle error (2)
EngineStatusError (2), Detailed Error Code: 00000002 at StreamId:5 vcId:0 CSIFrameId:0
nvmedia: ERROR: MAX96712: Link 0: GMSL2 decoding error (6)
EngineStatusError (2), Detailed Error Code: 00000200 at StreamId:5 vcId:0 CSIFrameId:0
Please provide the following info:
Hardware Platform: DRIVE AGX Xavier™ Developer Kit
Software Version: DRIVE Software 10
Host Machine Version: native Ubuntu 18.04
SDK Manager Version:
