Here is the complete output of sample_camera:
WindowEGL: find EGL devices
WindowEGL: found 2 EGL devices
WindowEGL: init EGL with GLES3 context
WindowEGL: bind OpenGLES3 API
WindowEGL: offscreen mode -> use EGL PBuffer surface 1280x800
WindowEGL: create EGL context
WindowEGL: assign EGL context to current thread
[11-02-2021 23:20:37] Platform: Detected DDPX - Tegra A
[11-02-2021 23:20:37] TimeSource: monotonic epoch time offset is 1612989293461152
[11-02-2021 23:20:37] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[11-02-2021 23:20:37] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[11-02-2021 23:20:37] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[11-02-2021 23:20:37] Platform: number of GPU devices detected 2
[11-02-2021 23:20:37] Platform: currently selected GPU device discrete ID 0
[11-02-2021 23:20:37] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[11-02-2021 23:20:37] SDK: No resources(.pak) mounted, some modules will not function properly
[11-02-2021 23:20:37] SDK: Create NvMediaDevice
[11-02-2021 23:20:37] SDK: Create NvMedia2D
[11-02-2021 23:20:37] SDK: use EGL display as provided
[11-02-2021 23:20:37] Initialize DriveWorks SDK v3.5.75
[11-02-2021 23:20:37] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[11-02-2021 23:20:37] Rig::fromFile: Loading rig file: rigs/IMX390_RGGB_C0.json
[11-02-2021 23:20:37] No valid data file found for camera:sample4 in parameter string: camera-name=IMX390RGGBE3_200FOV_RGGB,interface=csi-e,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216 (using configuration folder rigs/)
onInitialize: creating camera.gmsl with params: camera-name=IMX390RGGBE3_200FOV_RGGB,interface=csi-e,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[11-02-2021 23:20:37] SensorFactory::createSensor() -> camera.gmsl, camera-name=IMX390RGGBE3_200FOV_RGGB,interface=csi-e,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[11-02-2021 23:20:37] CameraBase: pool size set to 8
[11-02-2021 23:20:37] SensorFactory::createSensor() -> camera.gmsl.master,
[11-02-2021 23:20:37] CameraMaster::parseDevBlock Getting device info list.
[11-02-2021 23:20:37] devBlock: 1 Slave = 0 Interface = csi-e Camera_name = IMX390RGGBE3_200FOV_RGGB Link = 0
[11-02-2021 23:20:37] Camera Match Name: IMX390RGGBE3_200FOV_RGGB Description: IMX390 RGGB module - 200-deg FOV, MIPI-IMX390, MAX9295 linkIndex: 4294967295 serInfo.Name: MAX9295
[11-02-2021 23:20:37] Client, Setting up information for camera ID 0
[11-02-2021 23:20:37] Client, successfully found info for camera ID 0 bound to id 0
[11-02-2021 23:20:37] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/IMX390RGGBE3_200FOV_RGGB.nito
[11-02-2021 23:20:37] Initialize DriveWorks VisualizationSDK v3.5.75
[11-02-2021 23:20:37] Initialize DriveWorksGL SDK v3.5.75
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
[11-02-2021 23:20:38] StreamConsumerGL: successfully initialized
[11-02-2021 23:20:38] StreamProducerCUDA: successfully initialized
[11-02-2021 23:20:38] CameraClient: camera params: format=mp4,type=disk,file=/home/nvidia/embark/videos//IMX390_RGGB_C0_2021_02_11_11_20_PM.mp4
[11-02-2021 23:20:38] CameraClient: serializer bitrate not specified. Using 8000000.
[11-02-2021 23:20:38] EncoderNvMedia: Setting encode on instance 0
Main: Starting master.
[11-02-2021 23:20:38] CameraGSMLMaster: starting...
[11-02-2021 23:20:38] SIPLMaster::SIPLMaster: Setting up master camera
[11-02-2021 23:20:38] Platform:
[11-02-2021 23:20:38] Platform Config:
[11-02-2021 23:20:38] Description:
[11-02-2021 23:20:38] Number of device blocks: 1
[11-02-2021 23:20:38] Device Block : 0
[11-02-2021 23:20:38] csiPort: 6
[11-02-2021 23:20:38] i2cDevice: 1
[11-02-2021 23:20:38] Deserializer Name: MAX96712
[11-02-2021 23:20:38] Deserializer Description: Maxim 96712 Aggregator
[11-02-2021 23:20:38] Deserializer i2cAddress: 41
[11-02-2021 23:20:38] Simulator Mode: 0
[11-02-2021 23:20:38] Slave Mode: 0
[11-02-2021 23:20:38] Phy Mode: 1
[11-02-2021 23:20:38] Number of camera modules: 1
[11-02-2021 23:20:38] CameraModule index: 0
[11-02-2021 23:20:38] Name :IMX390RGGBE3_200FOV_RGGB
[11-02-2021 23:20:38] Description: IMX390 RGGB module - 200-deg FOV, MIPI-IMX390, MAX9295
[11-02-2021 23:20:38] Serializer name: MAX9295
[11-02-2021 23:20:38] Serializer description: Maxim 9295 Serializer
[11-02-2021 23:20:38] Serializer i2cAdress: 98
[11-02-2021 23:20:38] EEPROM name: N24C64
[11-02-2021 23:20:38] EEPROM i2cAddress: 80
[11-02-2021 23:20:38] EEPROM description: N24C64 EEPROM
[11-02-2021 23:20:38] Sensor ID: 0
[11-02-2021 23:20:38] Sensor name: IMX390
[11-02-2021 23:20:38] Sensor description: Sony IMX390 Sensor
[11-02-2021 23:20:38] Sensor i2cAddress: 26
[11-02-2021 23:20:38] Sensor isTPGEnabled: 0
[11-02-2021 23:20:38] Sensor isTriggerMode: 1
[11-02-2021 23:20:38] cfa: 33
[11-02-2021 23:20:38] embeddedTopLines: 3
[11-02-2021 23:20:38] embeddedBottomLines: 0
[11-02-2021 23:20:38] inputFormat: 8
[11-02-2021 23:20:38] height: 1220
[11-02-2021 23:20:38] width: 1936
[11-02-2021 23:20:38] fps: 30.0000000
[11-02-2021 23:20:38] Embedded Data: 1
[11-02-2021 23:20:38] CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[11-02-2021 23:20:38] Client, setting pipeline config for camera ID 0
[11-02-2021 23:20:38] CameraMaster: master initiation
MAX96712: Revision 2 detected
MAX96712 Rev 2: Link 0: Tx amplitude 0x28, 0x68, 0xb3, 0x72, 0xd2
MAX96712 Rev 2 manual adaptation on the link 0 (31)
MAX9295: Revision 8 detected!
Unsupported IMX390 revision 6 detected! Supported revisions are:
IMX390 Rev 0
IMX390 Rev 1
IMX390 Rev 2
IMX390 Rev 3
DEVBLK_WORKER_0: CNvMMAX96712_9295_IMX390.cpp: 82: DetectModule: DevBlkCDICheckPresence in CNvMIMX390::Init failed failed! with NvMedia error: 6
DEVBLK_WORKER_0: CNvMMAX96712CameraModule.cpp: 66: Init: Sensor Detection failed! with error: 7f
DEVBLK_WORKER_0: CNvMDeviceBlock.cpp: 249: Init: Init failed for module on link = 0
DEVBLK_WORKER_0: CNvMDeviceBlockMgr.hpp: 147: ThreadFunc: Device block init failed(7f)
sample_camera: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
sample_camera: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
sample_camera: CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
[11-02-2021 23:20:38] CameraMaster: master init failed127
sample_camera: CNvMCamera.cpp: 568: GetImageAttributes: Incorrect pipeline state:1 for pipeline:0
[11-02-2021 23:20:38] CameraMaster: GetImageAttributes failed6
[11-02-2021 23:20:38] CameraClient: GetImageAttributes failed6
[11-02-2021 23:20:38] CameraClient: Failed to allocate images groups!6
[11-02-2021 23:20:38] Driveworks exception thrown: DW_FAILURE: CameraClient: Failed to allocate images pool!
terminate called after throwing an instance of 'std::runtime_error'
what(): [2021-02-11 23:20:38] DW Error DW_FAILURE executing DW function:
dwSensor_start(m_camera[i])
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/sensors/camera/camera/main.cpp:366
./record_IMX390.sh: line 9: 23332 Aborted (core dumped) $DRIVEWORKS/bin/sample_camera --rig $RIG_FILE --write-file $VIDEO_FILE --offscreen=2
