Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.0.10816
other
Host Machine Version
native Ubuntu 18.04
other
NVMedia’s ./nvsipl_camera is able to detect camera, and print FPS, and write frames to .yuv file.
DriveWorks’s ./sample_camera is able to match camera name, serializer, and .nito file, but unable to set pipeline configuration.
[21-12-2022 11:19:39] Initialize DriveWorks SDK v4.0.0
[21-12-2022 11:19:39] Release build with GNU 7.3.1 from no-gitversion-build against Drive PDK v5.2.6.0
[21-12-2022 11:19:39] Rig::fromFile: Loading rig file: /usr/local/driveworks/data/samples/sensors/camera/camera/rig_ov2311p.json
[21-12-2022 11:19:39] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[21-12-2022 11:19:39] No valid data file found for camera:sample0 in parameter string: camera-name=OV2311P,interface=csi-e,link=0,output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8 (using configuration folder /usr/local/driveworks/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=OV2311P,interface=csi-e,link=0,output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8
[21-12-2022 11:19:39] SensorFactory::createSensor() → camera.gmsl, camera-name=OV2311P,interface=csi-e,link=0,output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8
[21-12-2022 11:19:39] CameraBase: pool size set to 8
[21-12-2022 11:19:39] SensorFactory::createSensor() → camera.gmsl.master,
[21-12-2022 11:19:39] CameraMaster::parseDevBlock Getting device info list.
[21-12-2022 11:19:39] CameraClient, setting isp-mode to yuv420-uint8
[21-12-2022 11:19:39] CameraClient, isp-mode set to yuv420-uint8
[21-12-2022 11:19:39] devBlock: 1 Slave = 0 Interface = csi-e Camera_name = OV2311P Link = 0
[21-12-2022 11:19:39] Camera Match Name: OV2311P Description: OV2311, MAX9295 linkIndex: 4294967295 serInfo.Name: MAX9295
[21-12-2022 11:19:39] Client, Setting up information for camera ID 0
[21-12-2022 11:19:39] CameraClient, YUV camera detected, overriding all output types to produce processed only output
[21-12-2022 11:19:39] Client, successfully found info for camera ID 0 bound to id 0
[21-12-2022 11:19:40] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/OV2311P.nito
[21-12-2022 11:19:40] Initialize DriveWorks VisualizationSDK v4.0.0
[21-12-2022 11:19:40] Initialize DriveWorksGL SDK v4.0.0
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
[21-12-2022 11:19:40] StreamConsumerGL: successfully initialized
[21-12-2022 11:19:40] StreamProducerCUDA: successfully initialized
Main: Starting master.
[21-12-2022 11:19:40] CameraGSMLMaster: starting…
[21-12-2022 11:19:40] SIPLMaster::SIPLMaster: Setting up master camera
resou…:1600x1300
resou…:1600x1300
CNvMMAX96712_9295_OV2311::SetSensorConnectionProperty
[21-12-2022 11:19:40] Platform:
[21-12-2022 11:19:40] Platform Config:
[21-12-2022 11:19:40] Description:
[21-12-2022 11:19:40] Number of device blocks: 1
[21-12-2022 11:19:40] Device Block : 0
[21-12-2022 11:19:40] csiPort: 6
[21-12-2022 11:19:40] i2cDevice: 1
[21-12-2022 11:19:40] Deserializer Name: MAX96712
[21-12-2022 11:19:40] Deserializer Description: Maxim 96712 Aggregator
[21-12-2022 11:19:40] Deserializer i2cAddress: 41
[21-12-2022 11:19:40] Simulator Mode: 0
[21-12-2022 11:19:40] Slave Mode: 0
[21-12-2022 11:19:40] Phy Mode: 0
[21-12-2022 11:19:40] Number of camera modules: 1
[21-12-2022 11:19:40] CameraModule index: 0
[21-12-2022 11:19:40] Name :OV2311P
[21-12-2022 11:19:40] Description: OV2311, MAX9295
[21-12-2022 11:19:40] Serializer name: MAX9295
[21-12-2022 11:19:40] Serializer description: Maxim 9295 Serializer
[21-12-2022 11:19:40] Serializer i2cAdress: 98
[21-12-2022 11:19:40] Sensor ID: 0
[21-12-2022 11:19:40] Sensor name: OV2311
[21-12-2022 11:19:40] Sensor description: Leopard camera built-in ISP (OV2311 + FPGA Output YUV)
[21-12-2022 11:19:40] Sensor i2cAddress: 96
[21-12-2022 11:19:40] Sensor isTPGEnabled: 0
[21-12-2022 11:19:40] Sensor isTriggerMode: 0
[21-12-2022 11:19:40] cfa: 4
[21-12-2022 11:19:40] embeddedTopLines: 0
[21-12-2022 11:19:40] embeddedBottomLines: 0
[21-12-2022 11:19:40] inputFormat: 0
[21-12-2022 11:19:40] height: 1300
[21-12-2022 11:19:40] width: 1600
[21-12-2022 11:19:40] fps: 60.0000000
[21-12-2022 11:19:40] Embedded Data: 0
[21-12-2022 11:19:40] CameraMaster available outputs: 8
[21-12-2022 11:19:40] CameraClient: setting pipeline config for camera ID 0
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 462: VerifyPipelineCfg: At least one output needs to be enabled
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 195: SetPipelineCfg: Invalid pipeline configuration
[21-12-2022 11:19:40] CameraClient: Failed to set Pipeline configuration for client with id 0, status 1
[21-12-2022 11:19:40] Driveworks exception thrown: DW_NVMEDIA_ERROR: CameraClient: Failed to set pipeline configuration!
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2022-12-21 11:19:40] DW Error DW_NVMEDIA_ERROR executing DW function:
dwSensor_start(m_camera[i])
at samples/sensors/camera/camera/main.cpp:367
Aborted
