I have created a program that can successfully capture GMSL imagery from a connected GMSL camera(SF3324).
But when I try to run multiple instances of the program in different windows the following error occurs:
[D] [13:24:14.255] CameraMaster: master initiation
DEVBLK_WORKER_0: pwr_utils.cpp: 196: PowerControlRequestOwnership: PowerControlRequestOwnership: nvccp_request_ownership failed with status (1005)
DEVBLK_WORKER_0: CNvMDeviceBlockMgr.hpp: 147: ThreadFunc: Device block init failed(7f)
ld-node-camera-: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
ld-node-camera-: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
ld-node-camera-: CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
The scenario is like this : Port A0 - GMSL camera SF3324, A1 - GMSL camera SF3324, A2 - GMSL camera SF3324.
I have given the parameters accordingly in the three instances : csi-a link-0, csi-a link-1, csi-a link-2. But only the camera started 1st is ran successfully. The other two are failing with the above error.
Protocol used is camera.gmsl, Do I need to use some other protocol for this?
I have not specified a rig file, so I think the default one is used.
I tried to launch a single camera in slave mode , but ran into the same issue.
std::string parameterString = std::string("output-format=yuv420-uint8,camera-name=SF3324");
parameterString += std::string(",slave=1");
parameterString += std::string(",interface=")+ std::string(settings.interface);
parameterString += std::string(",link=") + std::to_string(settings.link);
parameterString += std::string(",fifo-size=") + std::to_string(settings.fifoSize);
params.parameters = parameterString.c_str();
params.protocol = "camera.gmsl";
The complete Log for reference:
[D] [13:24:13.166] Configurations read - Interface : csi-a, Link : 1 FiFoSize : 4, FullResolution : 0, Compressed: true, LogLevel: trace
[T] [13:24:13.166] Platform: Detected DDPX - Tegra A
[D] [13:24:13.166] TimeSource: monotonic epoch time offset is 1628502824278816
[W] [13:24:13.166] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[E] [13:24:13.166] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[W] [13:24:13.167] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[T] [13:24:13.901] Platform: number of GPU devices detected 1
[T] [13:24:13.901] Platform: currently selected GPU device integrated ID 0
[T] [13:24:13.904] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[D] [13:24:13.905] SDK: No resources(.pak) mounted, some modules will not function properly
[D] [13:24:13.905] SDK: Create NvMediaDevice
[D] [13:24:13.905] SDK: Create NvMedia2D
[D] [13:24:13.916] egl::Display: found 1 EGL devices
[D] [13:24:13.917] egl::Display: use drm device: /dev/dri/card0
[D] [13:24:14.058] TimeSource: monotonic epoch time offset is 1628502824278816
[W] [13:24:14.058] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[E] [13:24:14.058] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[W] [13:24:14.058] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[D] [13:24:14.059] Initialize DriveWorks SDK v3.5.75
[T] [13:24:14.059] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[I] [13:24:14.059] Initialized SDK
[I] [13:24:14.060] Initialized Sensor Abstraction Layer
[D] [13:24:14.060] SensorFactory::createSensor() -> camera.gmsl, output-format=yuv420-uint8,camera-name=SF3324,interface=csi-a,link=1,fifo-size=4
[T] [13:24:14.060] CameraBase: pool size set to 8
[D] [13:24:14.060] SensorFactory::createSensor() -> camera.gmsl.master,
[D] [13:24:14.094] CameraMaster::parseDevBlock Getting device info list.
[D] [13:24:14.094] devBlock: 1 Slave = 0 Interface = csi-a Camera_name = SF3324 Link = 1
[D] [13:24:14.095] Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[D] [13:24:14.095] Client, Setting up information for camera ID 0
[D] [13:24:14.095] Client, successfully found info for camera ID 0 bound to id 0
[D] [13:24:14.247] CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[D] [13:24:14.247] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[T] [13:24:14.247] CameraGSMLMaster: starting...
[D] [13:24:14.247] SIPLMaster::SIPLMaster: Setting up master camera
[T] [13:24:14.254] Platform:
[T] [13:24:14.254] Platform Config:
[T] [13:24:14.254] Description:
[T] [13:24:14.254] Number of device blocks: 1
[T] [13:24:14.254] Device Block : 0
[T] [13:24:14.254] csiPort: 0
[T] [13:24:14.254] i2cDevice: 0
[T] [13:24:14.254] Deserializer Name: MAX96712
[T] [13:24:14.254] Deserializer Description: Maxim 96712 Aggregator
[T] [13:24:14.254] Deserializer i2cAddress: 41
[T] [13:24:14.254] Simulator Mode: 0
[T] [13:24:14.254] Slave Mode: 0
[T] [13:24:14.254] Phy Mode: 0
[T] [13:24:14.254] Number of camera modules: 1
[T] [13:24:14.254] CameraModule index: 1
[T] [13:24:14.254] Name :SF3324
[T] [13:24:14.254] Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[T] [13:24:14.255] Serializer name: MAX96705
[T] [13:24:14.255] Serializer description: Maxim 96705 Serializer
[T] [13:24:14.255] Serializer i2cAdress: 64
[T] [13:24:14.255] Sensor ID: 0
[T] [13:24:14.255] Sensor name: AR0231
[T] [13:24:14.255] Sensor description: OnSemi AR0231 Sensor
[T] [13:24:14.255] Sensor i2cAddress: 16
[T] [13:24:14.255] Sensor isTPGEnabled: 0
[T] [13:24:14.255] Sensor isTriggerMode: 1
[T] [13:24:14.255] cfa: 39
[T] [13:24:14.255] embeddedTopLines: 24
[T] [13:24:14.255] embeddedBottomLines: 4
[T] [13:24:14.255] inputFormat: 8
[T] [13:24:14.255] height: 1208
[T] [13:24:14.255] width: 1920
[T] [13:24:14.255] fps: 30.0000000
[T] [13:24:14.255] Embedded Data: 0
[D] [13:24:14.255] CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[D] [13:24:14.255] Client, setting pipeline config for camera ID 0
[E] [13:24:19.269] CameraMaster: master init failed127
ld-node-camera-: CNvMCamera.cpp: 568: GetImageAttributes: Incorrect pipeline state:1 for pipeline:0
[D] [13:24:19.270] CameraMaster: GetImageAttributes failed6
[D] [13:24:19.270] CameraClient: GetImageAttributes failed6
[D] [13:24:19.270] CameraClient: Failed to allocate images groups!6
[E] [13:24:19.270] Driveworks exception thrown: DW_FAILURE: CameraClient: Failed to allocate images pool!
[E] [13:24:19.270]
[C] [13:24:19.270] [2021-08-09 13:24:19] DW Error DW_FAILURE executing DW function:
dwSensor_start(mCamera)
at /home/nvidia/TCs/ld-node-camera-gmsl/builds-aarch64/ld-node-camera-gmsl_1628163020589/work/src/CameraGmsl.cpp:122
[D] [13:24:19.270] Deinit master camera
ld-node-camera-: CNvMCamera.cpp: 1088: Deinit: Incorrect pipeline state:1 for pipeline:0
[D] [13:24:19.270] Failed to Deinit master camera!6
[D] [13:24:21.270] CameraClient: Stopping client
[I] [13:24:21.287] Camera stopped and released
[D] [13:24:21.287] Releasing camera master
ld-node-camera-: CNvMCamera.cpp: 48: ~CNvMCamera: CNvMCamera object fails to deinit
nvmedia: ERROR: MAX96712: Bad parameter: Null ptr
ld-node-camera-: CNvMMax96712.cpp: 244: Deinit: CDI_CONFIG_MAX96712_DISABLE_REPLICATION failed! with NvMedia error: 1
ld-node-camera-: CNvMDeviceBlock.cpp: 353: Deinit: Deserializer Deinit failed[I] [13:24:21.288] Sensor Abstaraction Layer released
[D] [13:24:21.289] Releasing Driveworks SDK Context
[D] [13:24:21.289] SDK: Release NvMediaDevice
[D] [13:24:22.000] SDK: Release NvMedia2D
[I] [13:24:22.001] SDK released
In Main: Initialization failed
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
