Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Hardware Platform
other
Hi Nvidia Team,
I’m trying to run this ROS example from Nvidia GitHub - NVIDIA/dw-ros: ROS cross-compilation with DriveWorks , It works well for cameras in port A, nevertheless when I change the port to B I get:
[ INFO] [1635126665.766613616]: Advertising Camera Start and Camera Stop Services.
[ INFO] [1635126669.646880912]: Service params called are as follows: camera.gmsl camera-name=SF3324,interface=csi-b,link=0,output-format=processed
cdiRootDevOpen: can't open /dev/isc-mgr.0.b - No such file or directory
DevBlkCDIRootDeviceCreate: Unable to open root device
DEVBLK_WORKER_0: CNvMDeviceBlock.cpp: 218: Init: DevBlkCDIRootDeviceCreate failed!
DEVBLK_WORKER_0: CNvMDeviceBlockMgr.hpp: 147: ThreadFunc: Device block init failed(7f)
nv_sensors_prod: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
nv_sensors_prod: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
nv_sensors_prod: CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
nv_sensors_prod: CNvMCamera.cpp: 568: GetImageAttributes: Incorrect pipeline state:1 for pipeline:0
[ERROR] [1635126669.797701744]: Cannot start camera. Error: DW_FAILURE
nv_sensors_prod: CNvMCamera.cpp: 1088: Deinit: Incorrect pipeline state:1 for pipeline:0
^Cnv_sensors_prod: CNvMCamera.cpp: 1088: Deinit: Incorrect pipeline state:1 for pipeline:0
nv_sensors_prod: CNvMCamera.cpp: 48: ~CNvMCamera: CNvMCamera object fails to deinit
nvmedia: ERROR: MAX96712: Bad parameter: Null ptr
nv_sensors_prod: CNvMMax96712.cpp: 244: Deinit: CDI_CONFIG_MAX96712_DISABLE_REPLICATION failed! with NvMedia error: 1
I changed the interface to csi-b based on camera : The choice for csi-port, what am I doing wrong?
I have also checked this post but it’s still no clear.
VickNV
October 25, 2021, 1:55pm
3
Hi, @jber4282
Does the connection work with sample_camera or nvsipl_camera ?
Hi @VickNV
I’m sorry, I don’t really understand what you are asking, when I run sample_camera it displays the image of the camera 0 in port A.
This is what the rig file has:
camera-name=SF3324,interface=csi-a,link=0,output-format=processed
Are you asking me to change the interface to csi-band try to run it again? or which rig file should I use? how to edit it?
Dear @jber4282 ,
Yes. Vick asked to confirm if the basic camera sample working fine.
Connect the camera to port B0 and use rig file with below changes
Hi @SivaRamaKrishnaNV
This is what I see after running sample_camera with the suggested changes:
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ ./sample_camera
[26-10-2021 19:01:14] Platform: Detected DDPX - Tegra A
[26-10-2021 19:01:14] TimeSource: monotonic epoch time offset is 1635235077460840
[26-10-2021 19:01:14] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[26-10-2021 19:01:14] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[26-10-2021 19:01:14] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[26-10-2021 19:01:14] Platform: number of GPU devices detected 2
[26-10-2021 19:01:14] Platform: currently selected GPU device discrete ID 0
[26-10-2021 19:01:14] Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[26-10-2021 19:01:14] SDK: No resources(.pak) mounted, some modules will not function properly
[26-10-2021 19:01:14] SDK: Create NvMediaDevice
[26-10-2021 19:01:14] SDK: Create NvMedia2D
[26-10-2021 19:01:14] SDK: use EGL display as provided
[26-10-2021 19:01:15] TimeSource: monotonic epoch time offset is 1635235077460840
[26-10-2021 19:01:15] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[26-10-2021 19:01:15] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[26-10-2021 19:01:15] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[26-10-2021 19:01:15] Initialize DriveWorks SDK v3.5.75
[26-10-2021 19:01:15] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[26-10-2021 19:01:15] Rig::fromFile: Loading rig file: /usr/local/driveworks-3.5/data/samples/sensors/camera/camera/rig.json
[26-10-2021 19:01:15] No valid data file found for camera:sample0 in parameter string: camera-name=SF3324,interface=csi-b,link=0,output-format=processed (using configuration folder /usr/local/driveworks-3.5/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=SF3324,interface=csi-b,link=0,output-format=processed
[26-10-2021 19:01:15] SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3324,interface=csi-b,link=0,output-format=processed
[26-10-2021 19:01:15] CameraBase: pool size set to 8
[26-10-2021 19:01:15] SensorFactory::createSensor() -> camera.gmsl.master,
[26-10-2021 19:01:15] CameraMaster::parseDevBlock Getting device info list.
[26-10-2021 19:01:15] devBlock: 1 Slave = 0 Interface = csi-b Camera_name = SF3324 Link = 0
[26-10-2021 19:01:15] Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[26-10-2021 19:01:15] Client, Setting up information for camera ID 0
[26-10-2021 19:01:15] Client, successfully found info for camera ID 0 bound to id 0
[26-10-2021 19:01:15] CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[26-10-2021 19:01:15] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[26-10-2021 19:01:15] Initialize DriveWorks VisualizationSDK v3.5.75
[26-10-2021 19:01:15] Initialize DriveWorksGL SDK v3.5.75
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
[26-10-2021 19:01:15] StreamConsumerGL: successfully initialized
[26-10-2021 19:01:15] StreamProducerCUDA: successfully initialized
Main: Starting master.
[26-10-2021 19:01:15] CameraGSMLMaster: starting...
[26-10-2021 19:01:15] SIPLMaster::SIPLMaster: Setting up master camera
[26-10-2021 19:01:15] Platform:
[26-10-2021 19:01:15] Platform Config:
[26-10-2021 19:01:15] Description:
[26-10-2021 19:01:15] Number of device blocks: 1
[26-10-2021 19:01:15] Device Block : 0
[26-10-2021 19:01:15] csiPort: 1
[26-10-2021 19:01:15] i2cDevice: 0
[26-10-2021 19:01:15] Deserializer Name: MAX96712
[26-10-2021 19:01:15] Deserializer Description: Maxim 96712 Aggregator
[26-10-2021 19:01:15] Deserializer i2cAddress: 41
[26-10-2021 19:01:15] Simulator Mode: 0
[26-10-2021 19:01:15] Slave Mode: 0
[26-10-2021 19:01:15] Phy Mode: 0
[26-10-2021 19:01:15] Number of camera modules: 1
[26-10-2021 19:01:15] CameraModule index: 0
[26-10-2021 19:01:15] Name :SF3324
[26-10-2021 19:01:15] Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[26-10-2021 19:01:15] Serializer name: MAX96705
[26-10-2021 19:01:15] Serializer description: Maxim 96705 Serializer
[26-10-2021 19:01:15] Serializer i2cAdress: 64
[26-10-2021 19:01:15] Sensor ID: 0
[26-10-2021 19:01:15] Sensor name: AR0231
[26-10-2021 19:01:15] Sensor description: OnSemi AR0231 Sensor
[26-10-2021 19:01:15] Sensor i2cAddress: 16
[26-10-2021 19:01:15] Sensor isTPGEnabled: 0
[26-10-2021 19:01:15] Sensor isTriggerMode: 1
[26-10-2021 19:01:15] cfa: 39
[26-10-2021 19:01:15] embeddedTopLines: 24
[26-10-2021 19:01:15] embeddedBottomLines: 4
[26-10-2021 19:01:15] inputFormat: 8
[26-10-2021 19:01:15] height: 1208
[26-10-2021 19:01:15] width: 1920
[26-10-2021 19:01:15] fps: 30.0000000
[26-10-2021 19:01:15] Embedded Data: 0
[26-10-2021 19:01:15] CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[26-10-2021 19:01:15] Client, setting pipeline config for camera ID 0
[26-10-2021 19:01:15] CameraMaster: master initiation
sample_camera: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
sample_camera: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
sample_camera: CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
[26-10-2021 19:01:15] CameraMaster: master init failed127
sample_camera: CNvMCamera.cpp: 568: GetImageAttributes: Incorrect pipeline state:1 for pipeline:0
[26-10-2021 19:01:15] CameraMaster: GetImageAttributes failed6
[26-10-2021 19:01:15] CameraClient: GetImageAttributes failed6
[26-10-2021 19:01:15] CameraClient: Failed to allocate images groups!6
[26-10-2021 19:01:15] Driveworks exception thrown: DW_FAILURE: CameraClient: Failed to allocate images pool!
terminate called after throwing an instance of 'std::runtime_error'
what(): [2021-10-26 19:01:15] DW Error DW_FAILURE executing DW function:
dwSensor_start(m_camera[i])
at /dvs/git/dirty/gitlab-master_av/dw/sdk/samples/sensors/camera/camera/main.cpp:366
Aborted (core dumped)
It’s weird I see Device Block : 0, port B should be 1, right?
@SivaRamaKrishnaNV
The error message gave me the information I needed to solve the issue. Seems like port b is actually c when I change the rig file to:
camera-name=SF3324,interface=csi-c,link=0,output-format=processed
I’m able to see the image corresponding to the camera connected to B0.
VickNV
October 26, 2021, 1:33pm
8
Good to hear that you figured out the problem.
But did you mean connecting the camera to group b needs to run with “interface=csi-c” parameter?
correct, for group b interface is “csi-c”, for group c interface = “csi-e”
