Sesnor ov2311 init failed
Software Version
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-D00)
other
SDK Manager Version
[*] 1.9.2.10884
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I do as below:
sudo ./nvsipl_camera -c “LI-OV2311-VCSEL-GMSL2-60H_DPHY_x4” -d 1 -v 4 --link-enable-masks “0x0001 0x0000 0x0000 0x0000”
log as :
DEVBLK_WORKER_0: CNvMMax96712.cpp: 237: DoInit: Check deserializer is present
MAX96712: Revision 5 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 244: DoInit: Set deserializer defaults
MAX96712 Link 0: PHY optimization was enabled
nvsipl_camera: Queue timeout
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 147: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 231: WorkersDoAction: All worker threads finished action:1
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
sudo ./nvsipl_camera -c “V728S1-120V0_CPHY_x4” -d 1 -v 4 --link-enable-masks “0x0010 0x0000 0x0000 0x0000”
log as:
DEVBLK_WORKER_0: CNvMMax20087SyncAdapter.cpp: 67: CreatePowerDevice: Create Sync Adapter Driver
MAX20087: SM4 is successfully executed
MAX20087: SM5 is successfully executed
MAX20087: SM8 is successfully executed
MAX20087: SM17 is successfully executed
DEVBLK_WORKER_0: CNvMMax96712_Fusa_nv.cpp: 281: DoInit: Check deserializer is present
DEVBLK_WORKER_0: CNvMMax96712_Fusa_nv.cpp: 291: DoInit: Set deserializer defaults
MAX96712 Link 1: PHY optimization was enabled
MAX96712: SM26: MAX96712VerifyGPIOReadBackStatus issuccessfully executed
MAX96712: SM36: MAX96712VerifyGPIOOpenDetection issuccessfully executed
MAX96712: SM2,13,14: INTR4 value verified.Value: 0
MAX96712: SM1,4,9,34,40: INTR6 value verified.Value: fe
MAX96712: SM3,5,35: INTR10 value verified.Value: f
MAX96712: SM22: INTR12 MEM_ERR_OEN value verified.Value: 1
MAX96712: SM15: VIDEO_MASKED_OEN valueverified. Value: 3f
MAX96712: SM5: Verified MAX_RT_ERR_OENregisters enabled.
MAX96712: SM4: Verified VIDEO_RX0registers enabled.
MAX96712: SM3: Verified RX/TX_CRC_ENregisters enabled.
MAX96712: SM4,41: Verified VID_PXL_CRC_ERR_OEN andMEM_ECC_ERR2 bits are enabled.
MAX96712: SM15: Verified VDDCMP_INT_OEN andVDDBAD_INT_OEN bits are enabled.
MAX96712: SM20: Verified AUTO_ERR_RST_ENregister enabled.
MAX96712: SM20: Verified DEC_ERR_OENregister enabled.
MAX96712: SM20: Verified IDLE_ERR_OENregisters disabled.
DEVBLK_WORKER_0: CNvMMax96712_Fusa_nv.cpp: 303: DoInit: Get deserializer revision
DEVBLK_WORKER_0: CNvMMax96712_Fusa_nv.cpp: 320: DoInit: Set MIPI output mode
DEVBLK_WORKER_0: CNvMMax96712_Fusa_nv.cpp: 378: EnableLinks: Enabling links
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 806: Init: Initializing link 1
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 77: DumpLinkParams: Link parameters
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 78: DumpLinkParams: Link Index: 1
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 79: DumpLinkParams: Broadcast serializer addr: 0x40
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 80: DumpLinkParams: Serializer addr: 0x41
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 82: DumpLinkParams:
Broadcast sensor addr: 0x1c
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 84: DumpLinkParams: Sensor addr: 0x1d
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 86: DumpLinkParams: VCID: 1
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 88: DumpLinkParams: Embedded data type: false
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 90: DumpLinkParams: Trigger mode sync: true
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 92: DumpLinkParams: Frame rate: 30.00 fps
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 95: DumpLinkParams:
Broadcast EEPROM addr: 0xb0
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 96: DumpLinkParams: EEPROM addr: 0xff
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 97: DumpLinkParams: Simulator mode: 0
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 98: DumpLinkParams: Passive mode: 0
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 178: BasicCheckModule: Read revision
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 211: BasicCheckModule: Check config link lock
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_96717F.cpp: 224: BasicCheckModule: Setup address translations
may be libnvsipl_devblk_drv_ov2311.so & libnvsipl_devblk_drv_ov2311.so has problem? it have not query database ov2311?
Thanks for reaching out. In order to assist you further, could you please let me know which camera modules you are using? You can check if they are listed on the following pages:
Please let me know if you need any further assistance.
If I haven’t inserted the camera module. There are also the above logs; So I think the problem lies in libnvsipl_devblk_ddi.so did not call libnvsipl_devblk_drv_ov2311.so (sample source code, so I want to build this process, but sample code dismatch).
Could you please provide more details about the camera modules you are using and the specific goal you are trying to achieve?
I only test the code with libnvsipl_devblk_drv_ov2311.so. have not insert the camera sensor module. I want to rewrite the libnvsipl_devblk_drv_ov2311.so with my ov2311 module
In that case, I would like to inform you that camera driver development is out of the forum support scope. You may want to discuss with your nvidia representative first.
