Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
When running the IMX728 driver, we are getting the below error when using mask 0x1111 to enable acquisition on all 4 channels:
This used to work previously with exactly the same setup.
Now, only one channel seems to work when we enable the following mask 0x0001. Only Sensor0_out0 is returning a frame rate.
The camera module is not listed as supported on DRIVE AGX Orin Sensors & Accessories | NVIDIA Developer. Therefore, you’ll need to contact the provider or manufacturer who supplied the driver for additional support or information.
@VickNV, Is debug USB C cable from NVIDIA Orin necessary to be connected to Ubuntu Host when using the nvsipl_camera application?
What about the right side USB C cable?
@VickNV Yes, its related to the original topic because now none of the channels are working for the nvsipl_camera applications (in this topic I have said that one is working). I wanted to check if its one of my connections, as I had disconnected the right USB C cable when it was initially working, just wondering if I can disconnect the left too.
