Two(more than one) Sony IMX490/IMX728 cameras do not work simultaneously
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Two Sony IMX490/IMX728 cameras do not work simultaneously, but the test application nvsipl_camera works: nvsipl_camera -c “IMX490_RGGB_CPHY_x4” -m “0x1001 0x0000 0x0000 0x0000” --showfps, nvsipl_camera -c “IMX728_RGGB_CPHY_x4” --showfps -m “0x0000 0x0000 0x1100 0x0000”
Error String
Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::bootstrap failed with sipl status 10
Logs
[16-10-2025 11:28:20] Platform: Detected Drive Orin P3710
[16-10-2025 11:28:20] Adding variable DW_Base:DW_Version
[16-10-2025 11:28:20] Added variable DW_Base:DW_Version
[16-10-2025 11:28:20] Platform: number of GPU devices detected 1
[16-10-2025 11:28:20] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_06_10_03, Arch: ga10b
[16-10-2025 11:28:20] Platform: currently selected GPU device integrated ID 0
[16-10-2025 11:28:20] CUDLAEngine:getDLACount: CUDLA version is = 1004000
[16-10-2025 11:28:20] CUDLAEngine:getDLACount: Number of DLA devices = 2
[16-10-2025 11:28:20] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[16-10-2025 11:28:20] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/home/orin/Test1/data’: VirtualFileSystem: Failed to mount ‘/home/orin/Test1/data/resources.pak’
[16-10-2025 11:28:20] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.14/data
[16-10-2025 11:28:20] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.14/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.14/data/resources.pak’
[16-10-2025 11:28:20] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.14/targets/aarch64-Linux/lib/libdw_base.so.5.14
[16-10-2025 11:28:20] SDK: No resources(.pak) mounted, some modules will not function properly
[16-10-2025 11:28:20] egl::Display: found 1 EGL devices
[16-10-2025 11:28:20] egl::Display: use drm device: /dev/dri/card0
[16-10-2025 11:28:20] [16-10-2025 11:28:20] Initialize DriveWorks SDK v5.14.74
[16-10-2025 11:28:20] [16-10-2025 11:28:20] Release build with GNU 9.3.0 from buildbrain-branch-0-g30b7ba5bb0c against Drive PDK v6.0.8.0
[16-10-2025 11:28:20] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[16-10-2025 11:28:20] Found driver: time.nvpps
[16-10-2025 11:28:20] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
Error: Permission denied
[16-10-2025 11:28:20] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX728_RGGB,interface=csi-e,link=2,output-format=processed,isp-mode=yuv420-uint8,file-buffer-size=16777216,skip-eeprom=1,fifo-size=4
[16-10-2025 11:28:20] Found driver: camera.gmsl
[16-10-2025 11:28:20] CameraBase: pool size set to 8
[16-10-2025 11:28:20] SensorFactory::createSensor() → camera.gmsl.master,
[16-10-2025 11:28:20] Found driver: camera.gmsl.master
[16-10-2025 11:28:21] CameraMaster::parseDevBlock Getting device info list.
[16-10-2025 11:28:21] CameraClient, setting isp-mode to yuv420-uint8
[16-10-2025 11:28:21] CameraClient, isp-mode set to yuv420-uint8
[16-10-2025 11:28:21] devBlock: 0 Slave = 0 Interface = csi-e Camera_name = IMX728_RGGB Link = 2 GroupInit = 0
[16-10-2025 11:28:21] Camera Match Name: IMX728_RGGB Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717 linkIndex: 4294967295 serInfo.Name: MAX96717F
[16-10-2025 11:28:21] Authentication is disabled for camera IMX728_RGGB
[16-10-2025 11:28:21] Not an EEPROM supported camera IMX728_RGGB
[16-10-2025 11:28:21] Client, Setting up information for camera ID 0
[16-10-2025 11:28:21] Client, successfully found info for camera ID 0 bound to id 0
[16-10-2025 11:28:21] ImageStreamer(NvMedia → CUDA)
[16-10-2025 11:28:21] CameraClient: using NITO found at /usr/share/camera/IMX728_RGGB.nito
[16-10-2025 11:28:21] CameraClient: CVARS not registered for camera: IMX728_RGGB
[16-10-2025 11:28:21] SyncDriver: GPU device available, enabling CUDA sync
[16-10-2025 11:28:21] SyncDriver: enableCUDAPresync, object successfully created
[16-10-2025 11:28:21] SIPLMaster::SIPLMaster: Setting up master camera
[16-10-2025 11:28:21] Platform:
[16-10-2025 11:28:21] Platform Config:
[16-10-2025 11:28:21] Description:
[16-10-2025 11:28:21] Number of device blocks: 1
[16-10-2025 11:28:21] Device Block : 0
[16-10-2025 11:28:21] csiPort: 6
[16-10-2025 11:28:21] i2cDevice: 2
[16-10-2025 11:28:21] cphyRate_0: 2000000
[16-10-2025 11:28:21] cphyRate_1: 2000000
[16-10-2025 11:28:21] Deserializer Name: MAX96712
[16-10-2025 11:28:21] Deserializer Description: Maxim 96712 Aggregator
[16-10-2025 11:28:21] Deserializer i2cAddress: 41
[16-10-2025 11:28:21] Passive Mode: 0
[16-10-2025 11:28:21] Phy Mode: 0
[16-10-2025 11:28:21] Number of camera modules: 1
[16-10-2025 11:28:21] CameraModule index: 2
[16-10-2025 11:28:21] Name :IMX728_RGGB
[16-10-2025 11:28:21] Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717
[16-10-2025 11:28:21] Serializer name: MAX96717F
[16-10-2025 11:28:21] Serializer description: Maxim 96717F Serializer
[16-10-2025 11:28:21] Serializer i2cAdress: 66
[16-10-2025 11:28:21] EEPROM name: M24C64
[16-10-2025 11:28:21] EEPROM i2cAddress: 84
[16-10-2025 11:28:21] EEPROM description: M24C64 EEPROM
[16-10-2025 11:28:21] Sensor ID: 0
[16-10-2025 11:28:21] Sensor name: IMX728
[16-10-2025 11:28:21] Sensor description: Sony IMX728 Sensor
[16-10-2025 11:28:21] Sensor isTPGEnabled: 0
[16-10-2025 11:28:21] Sensor i2cAddress: 26
[16-10-2025 11:28:21] Sensor isTriggerMode: 1
[16-10-2025 11:28:21] cfa: 33
[16-10-2025 11:28:21] embeddedTopLines: 1
[16-10-2025 11:28:21] embeddedBottomLines: 20
[16-10-2025 11:28:21] inputFormat: 8
[16-10-2025 11:28:21] height: 2160
[16-10-2025 11:28:21] width: 3840
[16-10-2025 11:28:21] fps: 30.000000
[16-10-2025 11:28:21] Embedded Data: 0
[16-10-2025 11:28:21] CameraMaster available outputs: 1
[16-10-2025 11:28:21] CameraClient: setting pipeline config for camera ID 0
[16-10-2025 11:28:21] CameraClient, SIPLNotifier created
[16-10-2025 11:28:21] CameraMaster: master initiation
MAX96712: Revision 5 detected
MAX96712 Link 2: PHY optimization was enabled
MAX96717: Revision 4 detected!
Sensor IMX728 Rev 49 RGGB detected!
[16-10-2025 11:28:22] SIPLClient: ImageQueue timeout
[16-10-2025 11:28:22] SIPLNotifier: Event notification queue timeout
[16-10-2025 11:28:22] CameraMaster: Bootstrap NvSIPL and ClientPipelines complete
[16-10-2025 11:28:22] SyncDriver: GPU device available, enabling CUDA sync
[16-10-2025 11:28:22] SyncDriver: enableCUDAPresync, object successfully created
[16-10-2025 11:28:22] CameraClient: format not specified. Using mp4 in Codec Header.
[16-10-2025 11:28:22] CameraMaster: starting…
[16-10-2025 11:28:22] CameraClient: allocating image pool for ICP
[16-10-2025 11:28:22] Allocating NvSci group
[16-10-2025 11:28:22] CameraClient: allocate image pool for 0
[16-10-2025 11:28:22] Allocating NvSci ISP0 images
[16-10-2025 11:28:22] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[16-10-2025 11:28:22] Found driver: time.nvpps
[16-10-2025 11:28:22] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
[16-10-2025 11:28:22] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX728_RGGB,interface=csi-e,link=3,output-format=processed,isp-mode=yuv420-uint8,file-buffer-size=16777216,skip-eeprom=1,fifo-size=4
[16-10-2025 11:28:22] Found driver: camera.gmsl
[16-10-2025 11:28:22] CameraBase: pool size set to 8
[16-10-2025 11:28:22] SensorFactory::createSensor() → camera.gmsl.master,
[16-10-2025 11:28:22] Found driver: camera.gmsl.master
[16-10-2025 11:28:22] SIPLClient: Acquisition started
[16-10-2025 11:28:22] SIPLNotifier: Notification received from pipeline index:0 of type: NOTIF_WARN_ICP_FRAME_DROP
[16-10-2025 11:28:23] CameraMaster::parseDevBlock Getting device info list.
[16-10-2025 11:28:23] CameraClient, setting isp-mode to yuv420-uint8
[16-10-2025 11:28:23] CameraClient, isp-mode set to yuv420-uint8
[16-10-2025 11:28:23] devBlock: 0 Slave = 0 Interface = csi-e Camera_name = IMX728_RGGB Link = 3 GroupInit = 0
[16-10-2025 11:28:23] Camera Match Name: IMX728_RGGB Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717 linkIndex: 4294967295 serInfo.Name: MAX96717F
[16-10-2025 11:28:23] Authentication is disabled for camera IMX728_RGGB
[16-10-2025 11:28:23] Not an EEPROM supported camera IMX728_RGGB
[16-10-2025 11:28:23] Client, Setting up information for camera ID 0
[16-10-2025 11:28:23] Client, successfully found info for camera ID 0 bound to id 0
[16-10-2025 11:28:23] ImageStreamer(NvMedia → CUDA)
[16-10-2025 11:28:23] SIPLNotifier: Notification received from pipeline index:0 of type: NOTIF_WARN_ICP_FRAME_DROP
[16-10-2025 11:28:23] CameraClient: using NITO found at /usr/share/camera/IMX728_RGGB.nito
[16-10-2025 11:28:23] CameraClient: CVARS not registered for camera: IMX728_RGGB
[16-10-2025 11:28:23] SyncDriver: GPU device available, enabling CUDA sync
[16-10-2025 11:28:23] SyncDriver: enableCUDAPresync, object successfully created
[16-10-2025 11:28:23] SIPLMaster::SIPLMaster: Setting up master camera
[16-10-2025 11:28:23] Platform:
[16-10-2025 11:28:23] Platform Config:
[16-10-2025 11:28:23] Description:
[16-10-2025 11:28:23] Number of device blocks: 1
[16-10-2025 11:28:23] Device Block : 0
[16-10-2025 11:28:23] csiPort: 6
[16-10-2025 11:28:23] i2cDevice: 2
[16-10-2025 11:28:23] cphyRate_0: 2000000
[16-10-2025 11:28:23] cphyRate_1: 2000000
[16-10-2025 11:28:23] Deserializer Name: MAX96712
[16-10-2025 11:28:23] Deserializer Description: Maxim 96712 Aggregator
[16-10-2025 11:28:23] Deserializer i2cAddress: 41
[16-10-2025 11:28:23] Passive Mode: 0
[16-10-2025 11:28:23] Phy Mode: 0
[16-10-2025 11:28:23] Number of camera modules: 1
[16-10-2025 11:28:23] CameraModule index: 3
[16-10-2025 11:28:23] Name :IMX728_RGGB
[16-10-2025 11:28:23] Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717
[16-10-2025 11:28:23] Serializer name: MAX96717F
[16-10-2025 11:28:23] Serializer description: Maxim 96717F Serializer
[16-10-2025 11:28:23] Serializer i2cAdress: 66
[16-10-2025 11:28:23] EEPROM name: M24C64
[16-10-2025 11:28:23] EEPROM i2cAddress: 84
[16-10-2025 11:28:23] EEPROM description: M24C64 EEPROM
[16-10-2025 11:28:23] Sensor ID: 0
[16-10-2025 11:28:23] Sensor name: IMX728
[16-10-2025 11:28:23] Sensor description: Sony IMX728 Sensor
[16-10-2025 11:28:23] Sensor isTPGEnabled: 0
[16-10-2025 11:28:23] Sensor i2cAddress: 26
[16-10-2025 11:28:23] Sensor isTriggerMode: 1
[16-10-2025 11:28:23] cfa: 33
[16-10-2025 11:28:23] embeddedTopLines: 1
[16-10-2025 11:28:23] embeddedBottomLines: 20
[16-10-2025 11:28:23] inputFormat: 8
[16-10-2025 11:28:23] height: 2160
[16-10-2025 11:28:23] width: 3840
[16-10-2025 11:28:23] fps: 30.000000
[16-10-2025 11:28:23] Embedded Data: 0
[16-10-2025 11:28:23] CameraMaster available outputs: 1
[16-10-2025 11:28:23] CameraClient: setting pipeline config for camera ID 0
[16-10-2025 11:28:23] CameraClient, SIPLNotifier created
[16-10-2025 11:28:23] CameraMaster: master initiation
[16-10-2025 11:28:23] CameraMaster: master init failed with status = 10
[16-10-2025 11:28:23] Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::bootstrap failed with sipl status 10
[16-10-2025 11:28:23] Driveworks exception thrown: DW_CALL_NOT_ALLOWED: CameraClient: has not started
Dear @dmytro.syniuk ,
did you check with Sony on supported DRIVE OS + DW version?
Does that mean if you just include single camera in rig.json, you can run sample_Camera?
Could you also share the rig.json?
Clear the /var/log/syslog on target and set export DW_SIPL_NVMEDIA_VERBOSITY=4 and run the application and share /var/log/syslog , dmesg and application logs.
Yes, supported.
Yes, the sample_camera and my app work with one Sony(IMX490 or IMX728) camera.
Thank you!
sample_camera.txt.gz (23.1 KB)
camera-rig.json.gz (348 Bytes)
application.txt.gz (39.9 KB)
application_syslog.txt.gz (534 Bytes)
sample_camere logs with 2 cameras:
sample_camera_2cam.txt.gz (3.7 KB)
camera2-rig.json.gz (365 Bytes)
Hi @dmytro.syniuk ,
This log provided when running with single Sony camera?
Also, could you try connecting the each camera to a different port(instead of different link in same port) and see if it works?
Could you please provide any update?
Any update can be provided for this issue?
Could you please provide any update for this topic?
