When i am using yolov5m.engine for target detection in Deepstream. There is a delay between the output RTSP video stream and the source RTSP video stream, and this delay increases with the running time, when running for 9 hours, the delay reaches 3 minutes.
I try this instruction: #deepstream-app -c /deepstream_app_config_yoloV5.txt
Then the output video stream has a delay of about 15 seconds
The longer the running time, the greater the delay.
You should confirm the fps reached 25 to makes it work without no delay, since it’s a live stream. You can also set interval of nvinfer plugin to more than zero, so the resource usage could decrease a lot to reach the live streaming.
