It is normal to encode YUV files.but encode The YUV data obtained from CSI gstreamer will be miscoded.
hello zbit,
we would like to understand your environment setups.
for example,
- which JetPack release you’re working with.
- is this issue reproduced with v4l2 standard controls, please share your commands.
- seems there’s failure with moving objects, may I also know your sensor output frame rate?
thanks
