Hi Experts,
There is a warning trace when booting up Orin NX board with Jetson 6.2, Linux 36.4.3
I connect a 4K HDMI monitor with the DP port of Orin NX board.
[ 11.525920] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[ 11.525932] CPU: 2 PID: 141 Comm: kworker/u16:3 Tainted: G O 5.15.148-tegra #1
[ 11.525936] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS v36.4.0 08/09/2023
[ 11.525937] Workqueue: dce-async-ipc-wq tegra_dce_client_ipc_send_recv [tegra_dce]
[ 11.525952] Call trace:
[ 11.525952] dump_backtrace+0x0/0x1d0
[ 11.525962] show_stack+0x34/0x50
[ 11.525965] dump_stack_lvl+0x68/0x8c
[ 11.525969] dump_stack+0x18/0x3c
[ 11.525971] os_dump_stack+0x1c/0x28 [nvidia]
[ 11.526062] tlsEntryGet+0x110/0x120 [nvidia]
[ 11.526141] kdispArbAndAllocDisplayBandwidth_v04_02+0x274/0x290 [nvidia]
[ 11.526219] kdispInvokeDisplayModesetCallback_KERNEL+0xa8/0xf0 [nvidia]
[ 11.526297] hypervisorIsVgxHyper_IMPL+0x144/0x260 [nvidia]
[ 11.526375] tegra_dce_client_ipc_send_recv+0x100/0x200 [tegra_dce]
[ 11.526381] process_one_work+0x208/0x500
[ 11.526385] worker_thread+0x144/0x4a0
[ 11.526388] kthread+0x184/0x1a0
[ 11.526391] ret_from_fork+0x10/0x20
BTY, if I change another monitor or another DP-to-HDMI cable, the warning trace may disappear, but there is another error as below
[ 12.752477] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
Because the driver is very complicated, I can not handle it in short time.
So, could you please help to check it, and give me some advice to fix it?
thanks,
LImeng
