4K hdmi display shows no image when connecet to a Orin device
Hi Nvidia,
The 4K hdmi display shows no image when conneceted to our Orin-based device.
The model of the display is: Sculptor MU156LT.
The dmesg log is as below:
[   20.005523] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.3.1  Release Build  (root@)  Tue May 21 12:10:07 CST 2024
[   20.220160] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   20.220338] nvethernet 2310000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   20.492053] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[   20.492892] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[   20.495867] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[   20.562259] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[   20.925818] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[   20.925828] CPU: 5 PID: 191 Comm: kworker/u16:3 Tainted: G        W  O      5.10.104-tegra #1
[   20.925830] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 3.1-32827747 03/19/2023
[   20.925842] Workqueue: dce-async-ipc-wq dce_client_async_event_work
[   20.925845] Call trace:
[   20.925851]  dump_backtrace+0x0/0x1d0
[   20.925853]  show_stack+0x2c/0x40
[   20.925857]  dump_stack+0xd8/0x138
[   20.925914]  os_dump_stack+0x14/0x1c [nvidia]
[   20.925960]  nvAssertFailedBacktrace+0xb0/0xb8 [nvidia]
[   20.926003]  kdispArbAndAllocDisplayBandwidth_v04_02+0x274/0x288 [nvidia]
[   20.926045]  kdispInvokeDisplayModesetCallback_KERNEL+0xa8/0xf0 [nvidia]
[   20.926086]  dceclientHandleAsyncRpcCallback+0x17c/0x2f0 [nvidia]
[   20.926126]  osTegraDceClientIpcCallback+0x84/0xa8 [nvidia]
[   20.926130]  dce_client_async_event_work+0x88/0x190
[   20.926133]  process_one_work+0x1c0/0x4a0
[   20.926134]  worker_thread+0x50/0x420
[   20.926135]  kthread+0x148/0x170
[   20.926138]  ret_from_fork+0x10/0x18
[   24.940300] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[   42.491523] vdd-12v-sys: disabling
[   42.491539] vdd-3v3-ftdi: disabling
[   42.491543] avdd-cam-2v8: disabling
[   42.491550] dsi-vdd-1v8-bl-en: disabling
Any advice? Thanks!
Did you change the DCB already?
Yes, we have changed the DCB, and it works with other hdmi displays, including a AOC 4k display.
By the way, the version of Jetpack is 5.1.1
If this specific monitor issue, please try to test on latest jetpack.
Hi WayneWWW,
As we have not ported Jetpack6.1 so far, I tried on the jetpack6.0ga, and the monitor still did not work.
The serial log is as below:
jp60ga_serial.txt (150.9 KB)
Could you give some help?
Your log is full of error print from other registers. Are you sure this is a state that you can login?
I got this log from the debug serial port. After these error print, I can login through debug serial port, but the monitor shows nothing.
Could you share me the /var/log/Xorg.0.log?
The error register 0x31b00b4 is related to i2c and this is rare error.
Here is the /var/log/Xorg.0.log?
Xorg.0.log (19.7 KB)
There is no way to debug this specific monitor issue in such way.
Please share me the detailed monitor information here. Brand name/model name…etc.
The monitor information:
Brand : Sculptor
Model: MU156LT
Official website URL: 4K HDR400 MU156LT-便携显示器-雕塑家便携显示器-Sculptor-官方网站
Hi WayneWWW,
I got detailed dmesg logof 3 monitors( 2k songren monitor, 4k aoc monitor and 4k sculptor) by: insmod nvidia.ko NVreg_RmMsg=“:”.
The 2k songren monitor and 4k aoc monitor all work well.
2k_songren_hdmi.log (636.5 KB)
4k_aoc_hdmi.log (715.1 KB)
4k_sculptor_hdmi.log (854.9 KB)
Will this information be helpful?
