Jetson TX2 NX
DeepStream 6.0.1
JetPack 4.6
Yolo v5 6.0 (trained)
I can run yolov5, yolov7, yolor through the deepstream app (they are all not trained) but when I run the trained yolvo5, it doesn’t detect any targets (rightly or wrongly).I am sure that the model was able to detect the target in PyTorch.There are no errors reported in this process.
There are some samples for open source YoloVx models. DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Nvinfer is open source, you can refer to DeepStream SDK FAQ for the nvinfer debugging. You can check whether the input to TRT is correct.
The following FAQ may also provide some method for debugging.
