Thor Module DP and HDMI pins
Hello.
When we checked the datasheet and design guide of the AGX Thor, we noticed following statements in the display section.
In Design Guide: “Jetson Thor supports a standard DP 1.4 or HDMI v2.1 interface”
In Datasheet: “The NVIDIA Jetson T5000 provides 4x shared HDMI and DP ports.”
We want to make sure that these four ports won’t have the same video output and we can get four different video outputs from them. Could you please clarify?
  • The Jetson AGX Thor Developer Kit (which includes the T5000 module) provides 1x HDMI 2.0b and 1x DisplayPort 1.4a via the reference carrier board.
  • The Jetson T4000 and T5000 modules support up to 4 independent display outputs, each of which can be routed as HDMI 2.1 or DP 1.4a, depending on the custom carrier design.
  • These display heads are fully independent and can drive four different video outputs.
