Thrust::copy_if on multiple range
I have a double ** device_chunks, it points to ~100 double * chunk and each chunks contains ~ 100k double data.
now I would like to do a filtering on 100 chunk and each chunk has its own range.
My idea is to call thrust::copy_if 100 times. I’m wondering if each thrust::copy_if launch a new kernel? since the overhead of launching kernel is still quite large so I don’t want to launch 100 kernels.
I see thrust::copy_if is both __host__ and __device__, if I invoke it inside device, does it also launch new kernels? (i.e., I launch a kernel of 100 threads and each device thread invoke a thrust::copy_if)
What would be a efficient way to do this task? I suppose there must be someway to do this, but I might need to implement thrust::copy_if idea myself with some tweaks…
I’m assuming that the 100 arrays should be compacted independently, and not the same positions in each array. Otherwise, you could use thrust::zip_iterator for kernel fusion.
Each call to thrust::copy_if results in kernel launch. That will also be the case if you use dynamic parallelism from a kernel.
The problem with thrust is that you pay for 2 stream synchronizations for each call. One after the kernel launch, and one after the number of compacted elements has been transferred to host (to return the new end iterator). The next copy_if call cannot be overlapped with the compaction kernel of the previous call.
To avoid this and have more control, you can use cub::DeviceSelect CUB: cub::DeviceSelect Struct Reference
Thanks for the answer! Just one more question, it seems that dub::DeviceSelect can be invoked inside kernel code without extra overhead to launch a kernel-in-kernel, and in the performance bench it also outperform thrust…I’m just curious how does it achieve that and is there any drawback of this approach? (otherwise, why do we still need thrust…)
Thrust is easier to use because you do not need to handle temporary allocations and synchronization. Apart from that, there is no difference. If you would do the things that Thrust does manually with cub, i.e. allocation, kernel, sync, memcpy, sync, on each iteration, the code will be as slow as Thrust.
I do not think dynamic parallelism is free of overhead. Rather, it adds significant overhead. A simple benchmark on my machine shows the following times for 100 arrays with 100000 elements each.
normal thrust took 2.06877 ms
cached thrust took 1.80378 ms
dynamic parallelism thrust took 3.54576 ms
cub simulating cached thrust took 1.79715 ms
cub took 0.678496 ms
dynamic parallelism cub took 2.50576 ms
#include <cub/cub.cuh>
#include <thrust/copy.h>
#include <thrust/system/cuda/vector.h>
#include <thrust/system/cuda/execution_policy.h>
#include <thrust/host_vector.h>
#include <random>
#include <iostream>
#include <vector>
#include <cstdlib>
#include <sstream>
#include <map>
#include <cassert>
#include <string>
#define USE_DP
struct Op{
    __host__ __device__
    bool operator()(int i) const noexcept{
        return i % 4 == 2;
//from thrust example
struct not_my_pointer
  not_my_pointer(void* p)
    : message()
    std::stringstream s;
    s << "Pointer `" << p << "` was not allocated by this allocator.";
    message = s.str();
  virtual ~not_my_pointer() {}
  virtual const char* what() const
    return message.c_str();
private:
  std::string message;
// A simple allocator for caching cudaMalloc allocations.
struct cached_allocator
  typedef char value_type;
  cached_allocator() {}
  ~cached_allocator()
    free_all();
  char *allocate(std::ptrdiff_t num_bytes)
    char *result = 0;
    // Search the cache for a free block.
    free_blocks_type::iterator free_block = free_blocks.find(num_bytes);
    if (free_block != free_blocks.end())
      result = free_block->second;
      // Erase from the `free_blocks` map.
      free_blocks.erase(free_block);
    else
      // No allocation of the right size exists, so create a new one with
      // `thrust::cuda::malloc`.
      try
        // Allocate memory and convert the resulting `thrust::cuda::pointer` to
        // a raw pointer.
        result = thrust::cuda::malloc<char>(num_bytes).get();
      catch (std::runtime_error&)
        throw;
    // Insert the allocated pointer into the `allocated_blocks` map.
    allocated_blocks.insert(std::make_pair(result, num_bytes));
    return result;
  void deallocate(char *ptr, size_t)
    // Erase the allocated block from the allocated blocks map.
    allocated_blocks_type::iterator iter = allocated_blocks.find(ptr);
    if (iter == allocated_blocks.end())
      throw not_my_pointer(reinterpret_cast<void*>(ptr));
    std::ptrdiff_t num_bytes = iter->second;
    allocated_blocks.erase(iter);
    // Insert the block into the free blocks map.
    free_blocks.insert(std::make_pair(num_bytes, ptr));
private:
  typedef std::multimap<std::ptrdiff_t, char*> free_blocks_type;
  typedef std::map<char*, std::ptrdiff_t>      allocated_blocks_type;
  free_blocks_type      free_blocks;
  allocated_blocks_type allocated_blocks;
  void free_all()
    // Deallocate all outstanding blocks in both lists.
    for ( free_blocks_type::iterator i = free_blocks.begin()
        ; i != free_blocks.end()
        ; ++i)
      // Transform the pointer to cuda::pointer before calling cuda::free.
      thrust::cuda::free(thrust::cuda::pointer<char>(i->second));
    for( allocated_blocks_type::iterator i = allocated_blocks.begin()
       ; i != allocated_blocks.end()
       ; ++i)
      thrust::cuda::free(thrust::cuda::pointer<char>(i->first));
#ifdef USE_DP
__global__
void dpthrustkernel(int** d_data1, int** d_data2, int N, int* d_numselected, int numarrays){
    int k = threadIdx.x + blockIdx.x * blockDim.x;
    if(k < numarrays){
        auto ptr = thrust::copy_if(thrust::device,d_data1[k], d_data1[k] + N, d_data2[k], Op{});
        d_numselected[k] = thrust::distance(d_data2[k], ptr);
__global__
void dpcubkernel(int** d_data1, int** d_data2, int N, int* d_numselected, int numarrays){
    if(k < numarrays){
        std::size_t bytes = 0;
        cub::DeviceSelect::If(
            nullptr,
            bytes,
            d_data1[k],
            d_data2[k],
            d_numselected + k,
            N,
            Op{}
        void* tmp = malloc(bytes);
            tmp,
            bytes,
            d_data1[k],
            d_data2[k],
            d_numselected + k,
            N,
            Op{}
        cudaError_t status = cudaDeviceSynchronize();
        assert(status == cudaSuccess);
        free(tmp);
#endif
int main()
    constexpr int N = 100000;
    constexpr int numarrays = 100;
    constexpr int blocksize = 128;
    constexpr int gridsize = (numarrays + blocksize - 1) / blocksize;
    std::mt19937 gen(42);
    std::uniform_int_distribution<std::mt19937::result_type> dist(0,50000);
    cudaError_t status = cudaSuccess;
    std::vector<int> h_data(N);
    for(int i = 0; i < N; i++){
        h_data[i] = dist(gen);
    std::vector<int*> d_data1vec(numarrays);
    std::vector<int*> d_data2vec(numarrays);
    for(int i = 0; i < numarrays; i++){
        cudaMalloc(&d_data1vec[i], sizeof(int) * N);
        cudaMalloc(&d_data2vec[i], sizeof(int) * N);
        cudaMemcpy(d_data1vec[i], h_data.data(), sizeof(int) * N, cudaMemcpyHostToDevice);
    std::vector<int> h_numselected(numarrays);
    int* d_numselected; cudaMalloc(&d_numselected, sizeof(int) * numarrays);
    cudaEvent_t event1; cudaEventCreate(&event1);
    cudaEvent_t event2; cudaEventCreate(&event2);
    cudaEventRecord(event1);
    for(int k = 0; k < numarrays; k++){
        thrust::copy_if(thrust::device,d_data1vec[k], d_data1vec[k] + N, d_data2vec[k], Op{});
    cudaEventRecord(event2);
    cudaEventSynchronize(event2);
    float time = 0;
    cudaEventElapsedTime(&time, event1, event2);
    std::cerr << "normal thrust took " << time << " ms\n";
        cached_allocator thrustallocator;
            thrust::copy_if(thrust::cuda::par(thrustallocator),d_data1vec[k], d_data1vec[k] + N, d_data2vec[k], Op{});
        std::cerr << "cached thrust took " << time << " ms\n";
    int** d_data1ptrs; cudaMalloc(&d_data1ptrs, sizeof(int*) * numarrays);
    int** d_data2ptrs; cudaMalloc(&d_data2ptrs, sizeof(int*) * numarrays);
    cudaMemcpy(d_data1ptrs, d_data1vec.data(), sizeof(int*) * numarrays, cudaMemcpyHostToDevice);
    cudaMemcpy(d_data2ptrs, d_data2vec.data(), sizeof(int*) * numarrays, cudaMemcpyHostToDevice);
    #ifdef USE_DP
    dpthrustkernel<<<gridsize, blocksize>>>(d_data1ptrs, d_data2ptrs, N, d_numselected, numarrays);
    cudaMemcpy(h_numselected.data(), d_numselected, sizeof(int) * numarrays, cudaMemcpyDeviceToHost);
    std::cerr << "dynamic parallelism thrust took " << time << " ms\n";
    #endif
        nullptr,
        bytes,
        (int*)nullptr,
        (int*)nullptr,
        d_numselected,
        N,
        Op{}
    int* d_tmp; cudaMalloc(&d_tmp, bytes);
            d_tmp,
            bytes,
            d_data1vec[k],
            d_data2vec[k],
            d_numselected,
            N,
            Op{}
        cudaMemcpy(h_numselected.data(), d_numselected, sizeof(int), cudaMemcpyDeviceToHost);
    std::cerr << "cub simulating cached thrust took " << time << " ms\n";
            d_tmp,
            bytes,
            d_data1vec[k],
            d_data2vec[k],
            d_numselected + k,
            N,
            Op{}
    std::cerr << "cub took " << time << " ms\n";
    #ifdef USE_DP
    dpcubkernel<<<gridsize, blocksize>>>(d_data1ptrs, d_data2ptrs, N, d_numselected, numarrays);
    status = cudaEventSynchronize(event2);
    std::cerr << "dynamic parallelism cub took " << time << " ms\n";
    #endif
    return 0;
